A/C Pulley bearings
Old May 1, 2009 | 01:05 PM
Southtowns27's Avatar
A/C Pulley bearings
The other day the bearings in the A/C pulley on my truck started screaming. It happens when the compressor is disengaged and the pulley is just freewheeling, not running the compressor. I've never had one apart so I don't know what's in there. Can the bearings be serviced, or do I need a whole new compressor/clutch/pulley assembly?
Old May 1, 2009 | 11:26 PM
roughstock's Avatar
YOu can get a new bearing.
You need a special tool to hold the clutch still while you take the nut off. Then take two flat screw drivers on opposite sides and gently(and straight) pry off the clutch. Then take snap ring off and use a gear puller to pull the pulley off the shaft.
when removing the clutch, make sure you dont lose the shims (stack of small washers on shaft). the bearing is pressed into the rear of the pulley and is held in place by peening the edge over with a center punch. Take a die grinder and grind off the peens. press out, press in new bearing, peen edge over and reinstall. I have bearing number if you need it. I can get it tomorrow, its in the shop and im headed for bed.
let me know if you need more help.
Old May 2, 2009 | 12:10 AM
HotRodTodd's Avatar
Koyo #DAC3555RD3H
Mutt68
Sep 25, 2012 12:51 PM
roughstock
Jun 21, 2008 11:44 PM
Sonny
Nov 17, 2004 12:52 PM
Rauschbo
Jun 22, 2004 05:07 AM
Stamey
Jun 11, 2004 08:46 PM
