broken dipstick
Old Jul 8, 2007 | 12:47 PM
RenegadeT's Avatar
broken dipstick
I found the plastic handle to my dipstick on the ground....and the dipstick is stuck a few inches inside the tube. I tried reaching in with a pair of long tweezers, no good. It looks like I'll have to pull the dipstick tube off the block. I havent crawled under to investigate, decided to cool off first . Does the tube bolt to the block (or maybe oil pan) behind the starter? How much of a pain is this gonna be. Then I guess I'll need a new dipstick.
Old Jul 8, 2007 | 01:01 PM
CarlJensen's Avatar
One bolt and it comes right out. Replaced mine with the "new" design some time ago. Better seal on the bottom of the tube, got rid of the "O" ring design.
Old Jul 8, 2007 | 01:48 PM
RenegadeT's Avatar
Cool thanks. What is/where do I get this new design?
Old Jul 8, 2007 | 02:03 PM
Totallyrad's Avatar
RT, you might be able to use a little nylon string and a piece of wire to get it out. It may save you getting nasty pulling the tube.
Old Jul 8, 2007 | 05:39 PM
CarlJensen's Avatar
New design dip stick tube is at Dodge. Get the one with a sealing plug at the bottom instead of an "O" ring assy. Ask the parts guy to look for revisions on his part number if he tries to give you the old style.
Old Jul 9, 2007 | 10:22 PM
bmaden's Avatar
dipstick handle repair
Same thing happened to mine, I took the clamp off of the top of the tube and then pulled out the metal thingy that the tube goes into. I was able to pull out the dipstick with 4" medical clamps, I then put the handle back on the dipstick and used some copper wire to re-attach the handle to the stick.
I re-assembled the top of the tube and was back in business. took longer to find the tools than to fis the stick.
Bill
Old Jul 9, 2007 | 10:23 PM
bmaden's Avatar
I re-assembled the top of the tube and was back in business. took longer to find the tools than to fix the stick.
Bill
Old Jul 11, 2007 | 01:19 PM
RenegadeT's Avatar
Well, I'll try and salvage what I've got.
I'm not finding much on this newer revision. Only thing I know is Mopar p/n 4883345, $43 for dipstick only. The dealer told me the only variations are 12V / 24V, but didnt know the differences between the two.
Old Aug 18, 2007 | 10:38 PM
RenegadeT's Avatar
Well I finally got it out today. Before messing around at the block I figured I'd give it another try on the handle end. I removed the clamps and metal fitting on the end of the dipstick tube, then put a magnet of the outside of the plastic tube, so I knew where the end of the dipstick was. I then used a dental pick thing with the 90 degree bend broken off to fit in the tube, and was able to fish it out. It was about 5" deep.
So I can buy one from the Dodge dealer, hunt the boneyards, or try Cummins. The dipstick I pulled out had 3923128 MADE IN USA stamped on it. Looks like a Cummins p/n, but a quick internet search didnt turn up anything. I'll call my local Cummins dealer Monday.
One last note...its been so long since I broke it, I can't seem to find the old handle
Old Aug 18, 2007 | 10:46 PM
Totallyrad's Avatar
I just punched your part number in at http://www.reliablegoods.com/cgi-bin/sqlstore/index.cgi and it said $16.07 I believe. I'm not recommending them, they just gave me a return on the part number. If that's correct, I'd buy new.
Old Aug 19, 2007 | 09:28 AM
sjester's Avatar
Much cheaper buying from Cummins. I've bought two already and they were $20-30 delivered.
barngal6
Apr 20, 2019 10:13 PM
1985cucv
15
Apr 17, 2009 09:06 AM
NoSparkplugs
Apr 30, 2008 11:27 PM
Rpainter
21
Mar 8, 2008 02:36 PM
