Break Bolt on fuel pump???PLEASE HELP!!!
Old Oct 24, 2003 | 03:09 PM
GreyBoy's Avatar
Hey, Im having trouble removing the 'break bolt' on the fuel pump. Im trying to slide the cam plate forward.
So far, I have chiseled a flat slot for a flat head screw driver (as was recommeend to me by several others). The metal seems too week. When I try to turn it, the edges get ruined. Im just wondering if there is something else I can try. If the head gets ruined, what then???ks,
Please help!!!
Thanks,
Sam
Old Oct 24, 2003 | 03:40 PM
berner's Avatar
Re:Break Bolt on fuel pump???PLEASE HELP!!!
Take a small chisel or screwdriver and a small hammer and try to turn the screw by tapping ccw on the outside of the head. It shouldn't be too tight. If that doesn't work, you can centerpunch it and carefully drill the head off with a 5/16" drill bit. Once the head is gone and the AFC housing is off, you can easily turn the screw out with pliers. You'll have to get a 6mm (I think) bolt to replace it.
Old Oct 24, 2003 | 03:48 PM
Smokee's Avatar
For 10 bucks you can get a hand impact tool at Napa. I didn't have the heart to hack away with a chisel.
george
Old Oct 24, 2003 | 07:13 PM
GreyBoy's Avatar
Thanks for the help guys!!! I finally got it off with my very own impact tool = Large Flathead Screwdriver &&& 5lb Hammer!!!
With the plate forward, I can notice a good increase in power, not the necksnapping that you would find with injectors or a new plate, but I never expected that
Thanks,
Sam
Old Oct 25, 2003 | 12:15 AM
Watch This's Avatar
the way ive done it is take a torx bit thats just a little bigger than the hole in the screw and hit it inside it with a hammer and it turns right out
FordTrax
Apr 18, 2014 08:47 PM
New2Diesel
Feb 28, 2011 08:28 PM
J Lent
Oct 7, 2009 06:50 PM
Chip
14
Jun 21, 2009 03:59 AM
Red3quarter
Sep 6, 2008 11:56 PM
