Brake/ABS Light lights up doing brakestand
Old Jan 28, 2007 | 12:18 PM
Bobcat698's Avatar
When doing a brakestand, or just pushing the brake to the floor at a intersection for S&G, I can set off the ABS & Brake lights.
Any idea why this would happen? The brakes still work fine, but the light stays lit for about 5 minutes.
This also happens at the drag strip when building boost.
Thanks in advance.
Old Jan 28, 2007 | 12:25 PM
Fueling around's Avatar
Master cylinder is going bad?
Old Jan 28, 2007 | 12:30 PM
Bobcat698's Avatar
Well I notice that the brakes are spongy usually but if I make a emergency stop, my brakes will be hard/responsive for a few minutes, then go crappy again/spongy.
Old Jan 28, 2007 | 12:37 PM
woodrat's Avatar
The factory service manual, if you have access to one, has instructions for getting the ABS computer to give trouble codes telling you what is wrong.
Old Jan 28, 2007 | 12:40 PM
I had a Chevy van that acted the same way. Finally the pedal dumped to the floor and the brake light stayed on. Replaced the master and everything was good until the warranty expired (rebuilt). Spend $5 more for a new unit with lifetime warranty.
I've got brake problems in the cold weather, but I traced that to my power steering (hydro boost) system.
Old Jan 28, 2007 | 12:51 PM
Bobcat698's Avatar
Good info, thanks!
My hydroboost is brand new and is a high flow custom unit.
Could the master cylinder cause my power steering to suck as well, seeing as how the brakes get fluid from the PS pump FIRST and foremost before getting to the Power steering?
I noticed at the end of the 1/4 mile my brake pedal has hardly any resistance and is nearly at the floor, but the brakes work, just not very well.
Old Jun 10, 2008 | 03:40 PM
heykw's Avatar
what was the fix?
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
polaris800sp
Nov 13, 2008 05:35 PM
mr T
Feb 24, 2007 06:42 AM
