Boost Pressures?
Old Sep 3, 2006 | 04:18 PM
Earthmover627's Avatar
Boost Pressures?
Im new at this and wondering, how much boost should a holset H35XW put out when going down the highway with my 1998 12 valve. Mine at 70 mph is pulling 12lbs of boost at 2200 rpms is that normal or too much? and with my foot in it she will pull 21 or 22 lbs max.
Old Sep 3, 2006 | 06:36 PM
infidel's Avatar
On flat land empty, steady speed normal boost should be 7 psi or lower.
If you still have a cat it may be clogged.
Old Sep 3, 2006 | 08:39 PM
bmoeller's Avatar
HX35W actually.
If you have 4.10 gears, the 12# boost at that speed is normal. That is what I got stock, even with 5" exhaust and no muff. Max boost sounds good. Healthy truck.
These engines are stout. The headgasket will hold 40#+, depending on its condition. Had mine up to 45psi. No problems. IIRC, Joe Donnelly on the TDR was making 800hp on a stock shortblock.
http://dodgeram.org/tech/dsl/Facts/96specs.html
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Old Sep 3, 2006 | 10:08 PM
Thank you I have learned alot from the info posted. This web site is a life saver!
Garrett5462
Jan 24, 2008 05:08 PM
O.T
Sep 18, 2007 12:50 PM
DMAN99
Jul 12, 2007 09:12 PM
toupee
Jun 27, 2007 04:19 PM
thumbs
Aug 3, 2003 09:06 PM
