-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   auto tranny up grade questions (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/auto-tranny-up-grade-questions-20729/)
boughtadodge Nov 28, 2002 11:57 AM
If I upgraded the torque converter and put on upgrade valve body will the rest of the tranny hold up if so how much can I go up in power with just doing these mods I would like to do the whole thing but 3500.00 wow.
Lary Ellis (Top) Nov 28, 2002 12:11 PM
Re:auto tranny up grade questions
My guess is you would just add more stress to the rest of the components causing them to fail prematurely. <br> Personnaly I will not start upping my own power till I have the Tranny to handle it. Which hopefully will not be too long from now!
Smokee Nov 28, 2002 05:12 PM
All depends on how you drive. My auto lasted for 320,000Km. The trannies are not really bad, but remember to keep the revs up before going into OD, and limit the number of WOT starts from a stop.<br>Hope you get the right stuff!
98rammer Nov 28, 2002 05:24 PM
think about throttle/line pressures versus your power curve/shift points...and many other factors. like i've said before, i know someone who has put 82 or 85,000 miles on his truck with just a valve body and torque converter. he's had BD8's in his truck for at least 5 months that i know of, NOS, twins, FMS, etc...making 640hp at the last dyno day. he says that he raced almost every weekend...never broke a shaft or anything (yeah, he CAN drive his truck like most us can't-taught me a lot when it comes to that stuff). Now the tranny is broken.<br><br>i'm not saying it's the best thing to do, because it's bound to break sometime or another, but those two alone can hold some good power and be reliable.<br><br>Tom
chuck3 Nov 28, 2002 09:39 PM
[quote author=boughtadodge link=board=16;threadid=7653;start=0#73401 date=1038506279]<br>If I upgraded the torque converter and put on upgrade valve body will the rest of the tranny hold up if so how much can I go up in power with just doing these mods I would like to do the whole thing but 3500.00 wow.<br>[/quote] <br><br> Who charges that much for the upgrades ATS ? My DTT didn't cost but about little over half that. ???
boughtadodge Nov 28, 2002 09:43 PM
I was looking ats website and that is what it said the whole trans with converter would cost where did you get yours I might go ahead and do it if it was under two grand. Matt
chuck3 Nov 28, 2002 09:47 PM
www.dieseltrans.com ;)
phox_mulder Nov 28, 2002 09:48 PM
Just the valve body and torque converter would be cheaper.
But, Heck, why not go all out and get the whole transmission.
3499.00 but figure in shipping and install too.
Do I hear 4,000?
How 'bout billet input and output shafts too?
phox
Lary Ellis (Top) Nov 28, 2002 09:51 PM
Seems like just getting a converter and valve body would just put more pressure on the rest of the tranny<br>
chuck3 Nov 28, 2002 09:54 PM
Top if you get the upgrades along with them you will be getting the same as you would with the whole trans. :)
phox_mulder Nov 28, 2002 09:57 PM
[quote author=SFtopSGT link=board=16;threadid=7653;start=0#73580 date=1038541891]<br>Seems like just getting a converter and valve body would just put more pressure on the rest of the tranny<br><br>[/quote]<br><br>That's why MHO is to get the whole transmission at once.<br>It will mesh together much better than adding a piece here, another there, etc.<br><br>Barring any unforseen problems between now and then, that's what I'll be doing in a couple of years.<br><br>Maybe I'll have a failure under warranty, and Dodge will be out of 47RE's and I'll get a 48RE put in ::).<br>If not, I'll be contacting one of the big three. <br>(names omitted to prevent a war).<br><br>phox
chuck3 Nov 28, 2002 10:04 PM
The TC and VB is the trans other than a few clutches, gears, shafts, seals and gaskets that can be upgraded. And the trans case.
phox_mulder Nov 28, 2002 10:11 PM
[quote author=CHUCK3 link=board=16;threadid=7653;start=0#73583 date=1038542653]<br> The TC and VB is the trans other than a few clutches, gears, shafts, seals and gaskets that can be upgraded. And the trans case.<br>[/quote]<br><br>If you upgraded all the clutches, gears, shafts, seals and gaskets, along with the TC and VB, would it still be cheaper than the whole transmission?<br>The old transmission I'm assuming would be returned with some kind of core charge? or deducted from the total replacement cost?<br><br>Oh, did I mention my top choice of the big three starts with a D and ends with a T ;D.<br><br>phox
John_P Nov 29, 2002 10:01 PM
boughtadodge:<br><br>The other members have already given you some<br>good advice!<br><br>Don't make the same mistake I did. At about 98,000<br>miles my &quot;stock&quot; transmission was beginning to show<br>wear. I began to experience the familiar 4th gear (O.D.) <br>&quot;shudder&quot; when I was towing my racing trailer in the<br>mountains. Thinking I could &quot;get by&quot; with just a new<br>TC and valve body after that many miles turned out<br>to be a mistake! About 3,000 miles after I had the<br>new TC and valve body installed, I began experiencing<br>a problem where the tranny wouldn't shift into third<br>gear right. Anyway, I ended up having to back into<br>the tranny to have new seals, clutch packs etc.<br>installed. <br><br>I would recommend saving up the money until you<br>have enough to completely go through your entire<br>transmission. This is especially true if your truck<br>has alot of miles on it.<br><br>Good luck!<br><br>---------<br>John_P
KatDiesel Nov 29, 2002 11:34 PM
[quote author=phox_mulder link=board=16;threadid=7653;start=0#73579 date=1038541688]<br>How 'bout billet input and output shafts too?[/quote]<br><br>That would make the price alot more, at the very least another $2000 if you got both input, output and front hub.
