Albatross243
Old Aug 20, 2009 | 10:46 PM
Albatross243's Avatar
Question Idle adjustment
Need to adjust idle RPM, can see no mechanical adjustment. Also when engine is shut off, I can hear a puff of air, just for an instant. Is there a pop off valve or could this be an Intercooler leak? Any advise??
98 2500 12 valve, 177,00 mi 2WD Auto trans
Old Aug 21, 2009 | 07:16 AM
bigfatricky's Avatar
Here you go.
http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
Old Aug 21, 2009 | 08:40 AM
BBWD's Avatar
The "puff of air" you are hearing could be the deflector for the defrost closing when the vacuum is removed when shutting down.
John (DH)
