AFC spring kit
AFC spring kit
??? Hay guys> like I said I'm new to this CTD an the bombing part so can some one tell me what this AFC spring kit is for. I'm ordering a cam plate an gauges from TST an they also have this spring kit, what is it an will it help with more power in the longrun.<br> I guess I read to many of your posts on here an now the Bombing starts on my truck. Told the wife I'm going to Bomb the truck an she looked at me like I was NUTS.<br> Hay thanks for all the help so far you guys have been great. ;D
Re:AFC spring kit
The afc controls (holds back/regulates) fueling until boost level comes up to support a clean burn. This is why you have the power/turbo lag if you goose the go pedal from idle. The afc has a small boost line connected that feeds pressure to the unit. The afc spring setting controls the boost point at where it allows power fueling to take place. In stock form you will have the lag and no smoke. Reduce the spring setting and you will have quicker acceleration and smoke. Amount of smoke will depend on spring tension and applied throttle/fueling. The afc adjustments applies to both stock and after market plates.
The spring kit is recommended for certain size fuel plates to aid in tuning afc to desired level. My TST #8 is doing ok without the optional kit.
Jerry
Jerry
shrmpboatcptn
Mar 7, 2008 12:34 AM
Hercules
Nov 13, 2007 02:40 PM
