Adjusting AFC, Starwheel
Old Aug 5, 2007 | 12:10 PM
CmminsBeast's Avatar
Can someone explain adjusting these items. I'm going to move my plate forward and want to adjust these at the same time.
Old Aug 5, 2007 | 12:26 PM
Box5's Avatar
Moving the starwheel forward reduces the load on the spring so it's easier for it to travel which should let more pre-boost fuel in. The afc forward just gives the arm a head start for travel which lets alittle more fuel go. Record ur fuel milage before and after because when I put my fuel plate full forward I lost 2 mpg, I think my gov arm needed to be adjusted though because i think it was just wasting fuel.
Old Aug 6, 2007 | 11:44 AM
Baja's Avatar
A very long article here, not written by me, lots of information. Should help.
Let's start with gov arm adjustment. Now maybe I'm just reading too much into it but I set my gov/plate contact with the engine running at idle with the AFC cover off. Why? I got to studying the stock plate and with the engine off, the common knowledge is to set the lever where all the cutaway images show....BELOW the big protrusion on the plate. Then I got to wondering about how that arm is smoothly going to ridse over that protrusion. So I looked at my 100 plate conmtact with the arm at rest (solenoid in run position tho) then fired up the engine and checked it again. The lever won't swing out until you lightly stab the throttle, but I noticed that the arm contacts the plate a lot higher than at rest. We can only attribute this to gov springs acting on the gov arm. So rather than set the plate with the engine off, I run it and set the plate to the arm with the enginre running. The difference in arm height is about 1/4 inch...coincidentally about how much higher the arm would have to be to clear that protrusion on the stock plate. So my belief is that when running, the arm starts on the protrusion and not below it as it would seem. Now not many of us are running stock plates, but the theory applies anyway. I have never had to adjust my gov arm to a plate.....except maybe the "0" I was running for a while. Now I'm not passing this along as gospel, or to shake the foundations everyone swears by, but if you car to dabble, have a go at it and see what I mean. While my engine is off, my arm will swing under the plate, but have never had it bind underneath...this is proof to me that my theory is correct. So if you're setting the bleeding edge, maybe setting the arm on the nose of that pointed plate would be better done while the engine is running.....and hopefully you can get the plate where you want it without adjusting the arm any!!
Next for the AFC.....several adjustments there, but not everyone understands them completely. At this point we know that the AFC is there to limit fuel supply during low, or no boost conditions. That's itsa only function, cut and dried, don't let anyone tell you differently. With a stock spring, after about 6 psi, no more AFC influence on the pump...that simple. If you have low tension springs in it, cut that down to about 2 psi. We know that the AFC lever protrudes down into the pump cavity right next to the fuel plate, and at no or low boost, it catches the gov arm and limits fuel that way. So what are we doing by moving the housing forward? We are simply moving THE ENTIRE ASSEMBLY farther to the front of the engine which allows the gov arm to travel farther which allows more fuel....that simple. So what about the star wheel? That wheel acts on a spring that pre-loads the pressure diaphram which is boost controlled. If we turn the starwheel towards the engine, it moves forward, releasing spring pre-load on the diaphram. As this pre-load goes away, it takes less boost to act on the diaphram and move the AFC lever out of the gov arm travel path. We think of these as the fine and coarse adjustments for the AFC, which is not totally true. The coarse adjustment is indeed moving the housing itself. But the fine adjustment is not the starwheel.....it's the so called smoke screw. You don't see this becasue it is on the back of the AFC housing under a sealed cover with a break off crew. This screw actually bottoms out on the diaphram center...from the boost side of the diaphram. And what happens when we add boost? The diaphram moves the AFC lever out of the way right? So by screwing this stud in, we give the lever a head start getting out of the way...much like moving the housing. That is why it is truly the fine adjustment. So we can set the housing in one position, then fine tune that position with the smoke screw. These adjustments alone will influence off idle smoke....not the star wheel. The star wheel will influence how long it takes to come off pre-boost fuel and into full fuel. So lets tune a pump...
We buy a truck and the previous owner moved the housing forward, cranked the starwheel fwd and didn't even know about the smoke screw...so it's in it's stock position. The thing smokes off the line like a freight train and bogs like crazy...then when 6 or 8 psi comes around, it surges with power and breaks all the tires loose....that darn turbo lag right? Now let's tune the afc.
Start by getting the access to the smoke screw...take the AFC off and remove the break off screw and smoke screw cover. Loosen the smoke screw lock nut and back out the screw several turns until it feels loose. Now screw it back in by hand until you can "JUST FEEL" the screw bottom out on the diaphram. Snug up the lock-nut a little and now set the AFC back to a middle position on the pump. Take out that hex plug on top of the AFC and bring the star wheel back from full forward about 3 full revolutions and put the plug back in. Now we have a starting point. Put her in gear and nail it. Do we have any smoke? No? then adjust that smoke screw a little at a time until it "just hazes" on take off. If you can't get that, loosen the smoke screw about halfway back out and reset the housing .020 farther fwd or so. Now try it again. Still no haze....adjust that screw in to get it. Or did we have too much smoke? back the screw off until it clears a little. You get the idea right? Any more than a slight haze off idle and you're wasting fuel, and maybe even hindering spool-up by quenching the cylinders with excess fuel and "puting the fire out" so to speak. So let's say we got the off idle launch looking good. Now it launches good but it takes too long for the turbo to come to life and the smoke goes away but no boost and it's laggy. That means we need to lessen the diaphram preload with the starwheel. This will hasten the curve out of pre-boost fuel control by allowing the diaphram to move with less boost pressure. Keep adjusting the wheel until there's a slight haze while you gauge shows less than 6 psi or so. If you get too much smoke once your RPM's start to climb, but before 6 psi or so, cranking the starwheel backwards will limit the fuel, cut the smoke, and smooth out the power. It's a balance game between the 3 adjustments....initial fuel delivery vs. building boost without quenching combustion. You'll know when you're right on....it'll launch hard, won't smoke, and boost climb will be smooth and rapid. These adjustments pertain mainly to the tune conscious driver, who wants drivability no matter who climbs behind the wheel, and isn't fueling for a funny car.
Now all of you have spotted my sig and said wait a minute...all this AFC tuning and he took his completley off...what gives? I DRIVE my truck, and my right foot does alot of the tuning as required at the timer of need!! You are not going to remove an AFC circuit and stomp the throttle from a stop and expect anything but a volcanic eruption with nothing to show for it!! You have to roll into the throttle as conditions demand, sometimes more, sometimes less. I like having that control, and not letting the pump decide for me with a one size fits all adjustment. I will tell you that boost response at speed is instant, and off-line punch is tremendous, once you learn how to drive it. Even at speed when our little boost gauges say 2-3 psi....guess who's holding the cards for you? Your AFC....still won't let you into full fuel until boost pressures are realized, and that just may be enough of a lag to give some half a car headstart during a rolling race.....excuse me....I meant to say when you need instant passing power. If you're a step on the loud pedal and go type of driver forget it...you won't like it. But...if you truly DRIVE your truck, give it a try....you just MIGHT like it.
To do this, you don't have to make a block off plate or remove the AFC housing entirely. You just need to remove the arm. This is easy....on the front of the AFC housing is a 10mm bolt that hold what looks like a bellcrank and shaft. Remove this bolt, then with a small screwdriver, pop the bellcrank loose and pull out the shaft. It will have o rings on it to seal the housing. Once this is out, lift out the AFC arm, put the shaft back in and snug up the retaining bolt again. Now it doesn't matter where the AFC housing is, or the smoke screw, or the starwheel....so just bolt it back on. re-attach your boost line....it'll still act oin the diaphram, but the diapohram won't be doing anything so don't worry about it. If you want to remove the AFC signal line go ahead...just remember to replace it with a plug in the manifold!! Now you right foot does all the adjusting for you on the fly, and is completely dynamic to conditions...cool huh? It only takes a few minutes to do, so if you don't like it, put her back in and forget about it.
Wow, this post is way long....sry guys. I have a habit of doing that. I hope I helped, but didn't confuse anyone.....
Old Aug 6, 2007 | 10:27 PM
ratsun's Avatar
Good post with lots of good info Baja
Old Aug 6, 2007 | 10:43 PM
Box5's Avatar
if u adjust the gov arm with the truck running, would the gov springs be spinning and throwing oil everywhere? I think I need to adjust my gov arm, and with it running sounds like the best way but im just worried about that.
Old Aug 7, 2007 | 10:15 PM
DRam11's Avatar
Baja: excellent post, great directions. But, I have a question. Some background first: recently I spent a couple weeks chasing down a lack of power problem that wasn't solved until the AFC was disassembled and the slotted plate inside straightened out. When it was put back on I slid the slotted plate and the AFC as far forward as possible. My sakes, for power! And smoke off idle.
After reading your post I followed the directions to the letter -- slid the AFC to mid-point, turned the starwheel back three turns and test drove it. Much less smoke off idle, and gobs less power on the highway. I have now taken the AFC back to full forward and gained most of the power (and smoke) back. Tomorrow I'm going to play around with the smoke screw and see if I can make the smoke go away. Maybe that will affect on-boost power.
My question: have you (or anyone) any idea why full-boost power is affected by the AFC? The article you posted claims there is no effect beyond just off-idle, but my experience is different.
Any thoughts?
Thanks.
DRam
Old Aug 7, 2007 | 11:34 PM
kelly mclean's Avatar
excellent piece Baja, but i'd like to divert it in another direction for a moment. if i'm experiencing emissions problems concerning smoke will this eliminate my problem. Y-N
Old Aug 8, 2007 | 10:44 AM
Baja's Avatar
Whoa, whoa, whoa....... wait a minute here guys. I am not a complete dunce, but I know my limits. In the first line of my post, part of it reads, "not written by me", in other words I am not the author of the article (but hey, thanks for the kudos), nor am I an expert on the AFC. I posted this article because it helped me learn and get a handle on how the AFC works. It helped me a lot so I thought I would pass it on. By reading it, you now know as much as I do. All I can say is play around with it until you are satisfied. My limits..... since I am not really qualified to answer some of the questions, my lack of answers will prevent me from making a complete fool of myself, which I have successfully done in the past. I am not trying to cop out here, just being honest. Keep reading and keep messing around with it like I did and good luck.
Old Aug 8, 2007 | 11:07 AM
DRam11's Avatar
Baja: Yup, read that first line and realized it was something you had not written. I just wondered if you or someone else on the forum had some ideas as to why I'm getting the results I am.
This morning I moved the starwheel about three turns forward and found all my power is back. Just off idle a heavy foot results in black smoke, a light foot controls it. At highway speeds - 65 or so - mashing the throttle in fifth gear gives a light haze from the tail pipe and a really quick run to red line. Now I'm going to fiddle with the smoke screw some and see what happens with off-idle smoke.
Thanks for the post. Even though my results aren't what it leads me to expect it's providing a chance to learn more about how the
Cummins fuel system operates.
Old Nov 14, 2007 | 11:11 PM
rolling18's Avatar
excellent info!! any pics of this process??
Old Nov 16, 2007 | 08:53 AM
waldersha's Avatar
Basically, the info in Baja's post helps to tune your truck so someone else getting in it and driving won't wreck something. It's trying to tell you how to tune is so that it has the power but won't smoke like a train. Of course, most of us don't care about that, just want as much power as we can get. If so, this isn't how you will like it. If you read further in the post you'll see that it talks about gutting the AFC. This will give you full fuel all the time, but you have to be really careful not to black out the road any time that you accelerate.
It's really just about personal preference. This is just a really good intro article about the relationship between fuel plate, AFC position and starwheel, and the "smoke screw" on the back of the AFC housing.
Old Nov 23, 2007 | 11:40 PM
DRam11's Avatar
Saw that about gutting the AFC, and decided not to take that route. Since my last post in this thread I've played around with the AFC position, fuel plate position, star wheel and smoke screw and have things running the way I like. There are still things to learn, though. Everyone says the AFC affects only low-boost, off idle fueling. But everything I've done with it affects on-boost performance from 1400 rmp up as well. Perhaps the governor needs to be adjusted or something, but until I have a little more information as to its operation and the how to, that will run as is.
Old Nov 24, 2007 | 11:59 AM
Clayten's Avatar
DTR's Toad Wrangler
You nailed it. If you have to wait till 1400 rpm your governor arm is to low.
Old Nov 24, 2007 | 03:26 PM
one54ton's Avatar
not to sabotage this thread but you access the starwheel by taking the large allen nut off of atop the pump right?
Old Nov 24, 2007 | 07:43 PM
Clayten's Avatar
DTR's Toad Wrangler
Yes that is correct.
