accumalator in 47rh
Old Oct 6, 2011 | 10:13 AM
ascs77's Avatar
accumalator in 47rh
hi everyone. i have a 47rh that i am rebuilding at the moment. problem is, when i tried to put the sonnax accumalator in, it sheared of one of the orings. is it supposed to be this tight? i ordered another seal kit for it and going to try and replace it this weekend.
Old Oct 6, 2011 | 11:50 AM
j-fox's Avatar
It is a little tight, did you force it? It is a common leak point and a good seal is best.
Are you sure it is the right seal? And lubed?
Old Oct 6, 2011 | 02:22 PM
ascs77's Avatar
ya, we lubed it, and for sure had to force it in. we actually had to use a shim to get it to start cause it would just pull the oring off. i couldnt believe it was so tight to get in.
Old Oct 7, 2011 | 05:17 PM
esde's Avatar
heat the oring in a glass of hot or boiling water right before installation. The heat will soften the rubber a bit.
Old Oct 7, 2011 | 11:35 PM
ascs77's Avatar
i will try that. is it supposed to be that tight in the bore? im sure it moves up and down, but it would take a lot of presure to do that.
whosdunit
Jul 16, 2011 11:51 PM
Sidewinder
Mar 9, 2004 07:03 PM
Crimedog
29
Feb 9, 2004 10:08 PM
ramguy
Jun 30, 2003 02:01 PM
BoldtsWagon
Jan 24, 2003 11:05 PM
