'95 grid heaters not working?
Well I never had a problem w/ the Grid heaters until today.
I went out to fire the rig up it is 22* out here.. and I noticed the "Wait to start" light did not light up? So I cycled the key on/off to see if it would turn on.
But no luck, I cranked the key and the engine started and idled roughly down to a stop.
I now have it plugged in and waiting for it to warm up a little.
Any idea on why the grid heaters, or the "Wait to start" light would die off?
-Jared
-Jared
Theres a temp sensor to tell the computer if it should turn on the heaters , then the relay to heaters , fusible links from batteries , having a wiring diagram is the best , maybe a search will bring that up .
From reading it seems like the fusible links & then relay is the most common .
Like John says, there is the intake air temp sensor just to the rear of the grids on the intake. Since your light isn't coming on i would suspect that since the light will come on even if the relay isn't working.It is the sensor that tells the computer to activate the grids. Then there is a smaller relay on the firewall beside the brake booster that controls the two larger relays down on the left inner fender.
We have an haynes manual down at the shop for the truck.
I was just trouble-shooting.
I searched on here and read about the fuseable link.
I checked all my fuses inside the truck and I had a blown 10AMP for the "Engine" not sure what all this runs. But I replaced the fuse and started it up and blew it again so I must have a shorted wire somewhere that I'm going to search for tomorrow.
I also lost my tach/speedo
but all other dash lights/signals work.
patdaly
25
Feb 2, 2008 10:39 PM
HOBrian
Sep 14, 2007 09:00 AM
