6bt in a bluebird ??
Old Apr 2, 2006 | 09:45 PM
jr22's Avatar
whats the biggest differance between a 190 hp 6bt in a bluebird bus and a 12v in a 94-98.5 dodge ???
Old Apr 2, 2006 | 10:08 PM
oestreich84's Avatar
8.3 liter in the bus compared to a 5.9 in the truck.
Old Apr 2, 2006 | 10:35 PM
P Kennedy's Avatar
If it was a 8.3 it would read 6CT, the engine shares most things but the fuel pump is the major difference. Fuel settings are designed for higher torque at less horse power.
pk
Old Apr 2, 2006 | 10:38 PM
I didnt know that they put 5.9's in busses. I guess you learn something new every day
Old Apr 2, 2006 | 10:58 PM
Smkndzl's Avatar
Quite a few buses out there with B5.9 , with one school district we removed 110 C8.3 and replaced them with common rail 5.9 ISB in the last three years, and the drivers are very happy with them we also have had to replace the lift pump on all of them except the last few so far
Old Apr 3, 2006 | 02:27 AM
johnzie's Avatar
We run 6bt's 5.9 engines in our single deck buses here in the UK.(Dennis Dart)..Coupled to a 3 speed Allison auto box..not the fastest thing on wheels...but good enough for what we call the 100yard dash..ie:- one bus stop to the other... . Quite a decent engine, we do have camshaft problems tho..Unladen 40 seater..6.5 tons..still gets about 12mpg....New stuff has the Common rail diesel...not been into them yet tho..
Old Apr 3, 2006 | 01:29 PM
Haulin_in_Dixie's Avatar
12 valve is pretty close to the same, might have a different timing case and cover for more air compressor clearance. Also has different pan and exhaust. 24 valve has different cam, timing case, exhaust, ECM, VP (lower rpm, higher torque) and real crappy injectors. Common rail is completely different engine, Dodge engine is special for the Dodge. Same block I guess, but gear case on other end.
Old Apr 3, 2006 | 01:36 PM
turbo thom's Avatar
Somewhat related, I've seen a number of 5.9's in motor homes. Still pushing around 30,000. One was a 160 HP 94. The man loved it. He liked it so much, rather than sell it, he replaced the interior.
Old Apr 3, 2006 | 07:43 PM
jr22's Avatar
I was thinking if there where close i could transplate 1 into a dodge ram add some get up to the pump and save some money over trying to find a 12v engine complete. everybody wants a fortune for there 12v where you can pick up a bus for around $1000 to $1500 thanks, jr
Old Apr 5, 2006 | 06:03 PM
Yep, bolts right in, just change what you have to to bolt it in.
Old Apr 5, 2006 | 06:41 PM
Bosshawg600's Avatar
Thats a good idea! I saw some bus 12v on ebay for around 1000. I need a new engine in my truck so i might check that out. Would all my go fast parts and stuff like that bolt up? I already have a finely tuned P pump and would like to put that back on so I guess that would bolt up too right?
Old Apr 5, 2006 | 07:58 PM
That is the key to the success of the Dodge. They put a truck or bus engine in a pickup.
Old Apr 5, 2006 | 08:53 PM
jr22's Avatar
thats what i am going to do part out a couple bluebirds and have a new motor because i was going to have to do pump work anyway so at least this is a lot more economic, jr
Old Apr 10, 2006 | 08:31 PM
suzukiZrider's Avatar
yup at the votec school i go to we got one thats a 91 and is intercooled and p-pumped
Robert Rausch
Nov 14, 2014 12:50 PM
trucksforu
Jan 11, 2006 09:59 PM
Lockdown
Nov 7, 2004 11:53 AM
southernsmoker
Apr 20, 2004 10:20 AM
