At 60mph...
Old Jan 12, 2007 | 11:59 AM
Captain's Avatar
welcome to the world of 4.10's The best millage I ever got after alot of $$ thrown at it was 19. Stock I got like 12. Our other truck witch is alos a 98 12v 4x4 5 speed stock for the past 330k miles has gotton abotu 23mpg withi 33" tall and narrow tires and 3.54 gears. With my 4.10's I average low 17's high 16's. We've never towed heavy but even stock with 33" tires the 3.54 pulled 5000# on a dual axel car trailer and you couldnt tell it was back there untill you stoped.
Old Jan 12, 2007 | 12:00 PM
TravisDj's Avatar
Originally Posted by Scramblinman
Something doesn't sound right here. 2200 rpm at 60 mph sounds too high for that tire size, even for 4.10 gears. 2200 rpms with the transmission in 5th gear (.73), 285/75R16s (32.8"), and a 3.54 axle gear ratio should put you at about 80 mph. 4.10 axle gears would lower that speed to about 70 mph.
Have you actually clocked your truck over a known distance to check the accuracy of the speedometer? Seen if it takes 60 seconds to travel exactly 1 mile at an indicated 60 mph? If that checks out, I think that your tachometer may be reading too high.
I will do all that stuff. My tach is at about 800 rpms once it warms up at idle. I will get exact numbers for ya. I may have been a little high on the rpms but not by much.
Old Jan 12, 2007 | 12:04 PM
TravisDj's Avatar
I start to defuel before I get to 70. Then it is a struggle to get up to 70.
Old Jan 12, 2007 | 12:17 PM
leprechaun's Avatar
I agree with Scramblinman.I have 4.10`s and 265/75R/16 tires[orig tire size 245`s.Adjusting for tire size i`m at 1800 RPM`s at 60,about 1950 RPM`s at 65,and about 2100RPM`s at 70.The overdrive ratio on my auto is .69 so if you have a 5-speed at .73 you will show a few more RPM`s.I`m a very conservative driver.I have never gotten less than 14.5 around town and usually get between 15.5 and 16.5.The best I`ve ever got was on the interstate with the cruise set at 60 - 21mpg.
Old Jan 12, 2007 | 12:38 PM
TravisDj's Avatar
I know for sure I'm over 2000 rpms at 60mph. I will get exact numbers on my drive home.
Old Jan 12, 2007 | 03:27 PM
jetsnow's Avatar
i have a 97 5spd with 4.10's and i'm at 2100rpm at 70mph and 1850rpm at 60mph and i get 17-21mpg empty. Something is weird with your truck.
Old Jan 12, 2007 | 03:47 PM
Captain's Avatar
if I ever get mine driving agian ill check but with my 4.10's at 75 I know was like 2600-2800rpm something like that and im pretty sure 60 was right around 2000 also
Old Jan 12, 2007 | 07:17 PM
TravisDj's Avatar
Ok I am doing 60mph and 2100 rpms. Would it really be worth the 4.10 to 3.55 conversion?
Old Jan 12, 2007 | 07:40 PM
leprechaun's Avatar
With 285`s [33" tall] your 4.10 ratio is reduced down to about a 3.78.I would save my money.I think your correction for tire size is off, or something.You should be doing 70mph@ 2200RPM with a 4.10 axle and 285`s.
Old Jan 12, 2007 | 08:34 PM
TravisDj's Avatar
I used GPS to check the accuracy of my speedo and I am actually going slightly slower than the speed says. I guess my gps unit could be off, but I dunno.
Old Jan 13, 2007 | 10:08 AM
54larry's Avatar
I have the exact same set up
as you but my 1996 truck is an auto. I have 4:10s, 285s etc. I hit about 63 mph (corrected ~7%) at 1950 rpms. at 2200 I am going at [I]least[I] 70. One of us is wrong somewhere.
Old Jan 13, 2007 | 10:11 AM
DieselDaze's Avatar
Larger tires can help reduce the rpms effectively changing the final drive ratio, but I see that you already have 285's.
Id agree that 2200 at 60 seems a little high.
Old Jan 13, 2007 | 10:33 AM
TravisDj's Avatar
Well after driving home yesterday I saw that I was at 2100 rpms at 60mph.
Old Jan 13, 2007 | 11:14 AM
leprechaun's Avatar
60mph @2100rpm with 33" tires would put your rear end ratio @ 4.56.I don`t think Dodge had that gearing as an option.I suppose you could have after market gearing installed by a previous owner.Either your tach is too high or your speedometer is reading low for 4.10 gearing.
Old Apr 26, 2008 | 11:04 AM
Keyser's Avatar
Dodge had 4.56 gears. My dad had one. I don't remember exactly how fast it was but it seems like 75 downhill with the wind at your back was tops.
