47RH parts help
My transmission build is being held up by 1 small part. There is a retaining washer that holds the valve in place in the governor. It is approx 1.130 OD x .667 ID x .020 thick made out of hardened steel. Mine is broke in 2 and the transmission re builder can't find a replacement. Anyone know where I can get one ASAP?
1 Attachment(s)
Originally Posted by cougar
(Post 3321168)
Attachment 47230 |
Yes, #13. I wouldn't be surprised if the previous overhaul shop put the wrong governor in it.
2 Attachment(s)
(Post 3321215)
If so, check out the weights.............. That might be the whole problem, I don't know if the kit is still available thru Chrysler. See below. Attachment 47231 Attachment 47232 |
None of the parts show as being made anymore.
Did find this, looks like the diesel governor from a A518 is the same, so you might have better luck finding one from a first gen spare trans........ Check out this thread. https://www.dieseltruckresource.com/...3/47rh-264004/ |
Turns out it is a V10 trans. I seriously want to hurt someone. The guy that's putting back together is going to replace all the necessary parts.
That's crazy! I assume your rebuilder know about Sonnax and Transtar as parts sources, but just in case...
