1995 ECM problem?
Old Jun 5, 2020 | 11:24 AM
rootercycles's Avatar
1995 ECM problem?
I have a 1995 Dodge Ram 2500 4x4 12 valve that will not start. I have a new starter, and it now "clicks" from the ECM behind the air cleaner on the passenger side. Is there a starter relay inside here that can be replaced? If not, are the ECMs from this generation interchangeable, or do they need to be "reflashed" in order to work. It started to click after trying to start it for a number of minutes a week or so ago.
Thanks for any help!
Todd
Old Jun 5, 2020 | 04:28 PM
'95 PCM will interchange with '94 PCM that had the same transmission, IE auto or manual.
Other year 2nd gen PCM are different and will not work for you.
If you end up needing one. I do have a couple of them in my shop.
Old Jun 10, 2020 | 08:32 AM
Is there a replaceable relay inside the ECM?
Old Jun 15, 2020 | 12:27 PM
changed both engine to battery grounds, and it turned right over!
Pike
May 17, 2018 09:12 PM
d22019
16
Feb 7, 2018 04:00 PM
Dalton Kingsley
Jan 25, 2017 08:35 AM
Diesel Dummy
Feb 3, 2008 02:45 PM
