1995 Alternator
Old Nov 14, 2009 | 02:29 PM
Greguw's Avatar
1995 Alternator
I have a 95 cummins coming in for a project , I would think the alt has a built in regulator , could some give me a run thru on what each wire is for .
Thanks
greg
Old Nov 14, 2009 | 03:16 PM
ET RAM's Avatar
The voltage regulator is in the PCM. The PCM senses system voltage and controls the alternator output.
You can add an external VR. if needed.
The alt. output B+ wire is the thick wire on the large terminal on rear of alt. The 2 small terminals are the field wires. The bottom is positive and the top is field driver.
Old Nov 14, 2009 | 04:59 PM
Greguw's Avatar
I did see a few post with external regulators , am I best converting to a GM style alternator or is the external a dependable route to go .
Thanks
Old Nov 14, 2009 | 07:37 PM
ET RAM's Avatar
Don't have an answer to your question.
Here is how the external VR is done. Most posts I have read are favorable regarding this mod. This will work on a 95.
VR
snic
15
Jun 14, 2017 11:29 AM
5.9Excursion
Mar 13, 2008 07:08 AM
Pat H
Sep 19, 2003 05:21 PM
Rocket95
Mar 1, 2003 07:03 PM
97CTD
Oct 10, 2002 10:11 PM
