1995 12 valve won't go over 50-55 mph
Old Mar 28, 2023 | 02:04 PM
nothingbutdarts's Avatar
delete
delete
Old Mar 29, 2023 | 05:42 PM
Robert Rausch's Avatar
Was it the fuel filter needed changing?
Old Mar 30, 2023 | 10:09 PM
I wish I could answer that, I was just trying to help someone on another forum, I tried to copy and paste it here, it would not fully post so I gave up. I could not find a way to delete the whole thread, so I just erased what I could.
Thanks for asking!
Old Mar 30, 2023 | 10:30 PM
Thx for replying. I had that happen to me once on a trip. At first it wouldn't go over 65, then 60, then 55, then 50. At that point I figured it was the fuel filter. I pulled off at the next rest stop and changed the fuel filter. Made a huge difference.
Old Apr 1, 2023 | 07:25 PM
I didn't get all this information posted then tried to delete the post: Intermittent no tack on dash, when tack works the truck will go full speed and the tranny will not lock up when tack didn't work. The crank sensor was replaced & no change, they have the PCM out for repair.
Thanks for the filter advice!
Old Apr 3, 2023 | 09:36 AM
texasprd's Avatar
The wiring harness for the engine speed sensor (ESS) can rub through at the front of the engine and short out - this could cause the intermittent symptoms you described.
Mibpoindexter
Feb 2, 2023 01:00 PM
Buckshotmckee
Mar 29, 2008 05:04 PM
megaboom
Mar 6, 2008 01:40 AM
Buckshotmckee
14
Nov 2, 2006 11:08 PM
Neppy
Aug 18, 2004 07:11 PM
