1995 12 valve CTD block heater removal??
is there a trick to removing block heater on a 1995 dodge ram cummins 12 valve I have removed bolt in center and have pulled on unit but only comes out about 1/8" and I have tried prying on lip at same time with no success.
thank you
thank you
Uh-Oh
The construction of the block heater is this: The metal plug you're pulling on has an o-ring groove cut in it. There's an o-ring in there, of course, to seal the hole. The plug is corroded to the block. That's why it's hard to remove. I'm guessing you're taking it out cause it's not working? If so, you can get rough with it. Yard that sucker outta there. Now the uh-oh part: The bolt in the center screws into a t-nut behind. When you took it all the way out, the t-nut fell down in the block. You will probably get it out with a magnet. Let's hope it's easy! ;D
Re:Uh-Oh
[quote author=HammerMTB link=board=16;threadid=23602;start=0#msg222411 date=1071200551]
[/quote]
good luck !!!
[/quote]
good luck !!!
drewsta
Apr 13, 2015 09:26 PM
texasredrider
Sep 14, 2006 12:50 AM
davedaddy
Dec 3, 2005 08:32 PM
1320
May 17, 2003 03:28 PM
