12v rough idle
Old Sep 20, 2019 | 03:35 PM
Big Bear84's Avatar
12v rough idle
Hi, guys!
I've got a strange issue with my 94' 12 valve. It fires up fine, has good power and doesn't smoke.
But idle is terrible.
Feels like it's too much fuel in pump cause i rev it up a little bit and release the throttle, but engine holds rpms few seconds and after that drops to idle.
https://youtu.be/NdIXnd_3ob4
So, whet it's cold, if i rev it up a little bit and release the throttle, it almost dies, but immidiately bumps back to idle. Whet it's hot, it does this thing only when i put it to gear.
https://youtu.be/AFMK7C-IcfY
So, details about truck:
P-pump replaced (warped plunger issue). Old pump was 838,new is 908. Installed 3k gsk kit, new OFV, lift pump, fuel filter. I did the 0 fuel plate, AFC is screwed up a little.
Truck didn't do this with old pump so i think that some is wrong with new pump.
Any ideas/advices will be fine. Thanks.
Tank_66
16
Jan 31, 2023 06:24 AM
Stude4x4
Mar 30, 2013 07:03 PM
richard
Feb 19, 2009 01:43 PM
Cummins4Life
Dec 20, 2007 05:44 PM
spitzair
Jan 30, 2006 04:53 PM
