12v. engine and drivetrain question
Old Apr 5, 2005 | 10:06 PM
Ian's Avatar
Ian
Hey guys,
I'm looking at a 1996 4x4 5sp, and every time I shift and hit the go pedal, truck makes a funny clunking noise combined with a bit of a lurch (not from a crappy shift lol), doesn't sound like ujoints either.
Also, I noticed the valve cover gasket was juicing out a bit of oil. Is that a tough fix?
Thanks for the help, its much appreciated!
Ian
Old Apr 5, 2005 | 11:03 PM
1320's Avatar
carrier bearing? pretty easy to tell....middle of the driveshaft.
Valve cover gaskets? easy.
Old Apr 5, 2005 | 11:24 PM
Ian's Avatar
Ian
mint, thanks 1320. Is the carrier bearing an easy fix too? I forgot to mention that it sounded like it was coming from the front...almost like the motor was bouncing around (as a vague illustration)
Old Apr 5, 2005 | 11:57 PM
1320's Avatar
The carrier bearing......sorta.....could be a PITA too....takes a press most of the time. I do know that my 98 "is special" and had to go to the dealer... but I think you ll find it at napa etc.....then pull the driveshaft and take it to a driveline place(20$ or so).....or just take it to the driveline place but they might get ya for some extra $$$.
Old Apr 6, 2005 | 10:31 AM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
maybe a broken front axle shaft flopping and bind up up front, mine makes that sound.....
DU.DP.
Oct 7, 2008 07:45 PM
raven5
Sep 18, 2006 11:15 AM
moparguy
Jan 9, 2005 10:29 AM
Mark Hodowanec
Aug 5, 2004 08:18 AM
