12v drivetrain problems
Old Oct 6, 2008 | 06:33 PM
DU.DP.'s Avatar
i just recently bought a 93 12v. when you turn to sharp it feels like its in 4wheel. the transfer case says 2H. and it feels like the u-joints in the rear may be going out. i dont know if its the axles or the transfer case causing it to make a sort of popping feeling. need some help. thanks
Old Oct 7, 2008 | 07:17 PM
DU.DP.'s Avatar
we found out the drivers side hub was shot! we replaced both because we had them on hand now i need to replace u-joints but does anyone know why the transfer case would be stuck in 4H? thanks
Old Oct 7, 2008 | 07:39 PM
Dartmouth 12V's Avatar
Is the transfer case stuck in 4wd or is the front axle not engaging? If the 4wd light works, if the light is on, then it is the collar on the front axle not disengaging. It is not common for a transfer case to get stuck in 4wd.
Old Oct 7, 2008 | 07:45 PM
DU.DP.'s Avatar
the light does work, but when driving the censor must be rubbing because the light goes on and off. and when you move the shifter from gear to gear its tough to move it.
LemonDodge
Jul 26, 2009 08:08 AM
Ian
Apr 6, 2005 10:31 AM
WKener
31
Jul 28, 2003 10:07 AM
northjeepster
Oct 15, 2002 01:11 PM
