1000 RPM squeeking?
Old Oct 19, 2006 | 06:57 AM
Txwelder's Avatar
1000 RPM squeeking?
Rolling down the road at just about idle, somewhere in the 20 mph range, if I give enough throttle to hold 1000 or so RPM, the truck makes this awful squeeking sound that sounds like a rolling wheel bearing about to go out completely. Let off the throttle or give it more throttle and it goes away. Any ideas as to what this may be? Driving me nuts and I cannot locate the problem because it only happens when the truck is rolling and I am away from home with no help right now. Thanks
Old Oct 20, 2006 | 06:50 PM
GearHd6's Avatar
Maybe its a loose clamp on you intercooler lines where the rubber connections are? And it only does it when its starting to make boost?
Old Oct 22, 2006 | 01:14 PM
mkrenn's Avatar
I had similar issue. Found out it was my idler pully.
Old Oct 22, 2006 | 04:48 PM
wilderness's Avatar
Check your pm.
Old Oct 23, 2006 | 05:30 AM
Txwelder's Avatar
Loose exhaust making funny noise. Thanks
Old Oct 23, 2006 | 06:35 AM
2500's Avatar
did you figure it out? loose exhaust pipe making noise?
would have thought it would be related to a bearing noise like: carrier brg which would only make noises when moving
Old Oct 23, 2006 | 10:33 AM
Txwelder's Avatar
Well I did think it was a bearing at first because it had that rotational squeek you know, like you could hear it going round and round. The thing was that when you let off the throttle it would stop squeeking even though the truck was still rolling. I got under there and discovered my exhaust needs some sprucing up. When it was straight piped some of the hangers were eliminated and it left room for play and it squeeks. Nothing some stacks wont take care of!
53 willys
31
Jan 31, 2008 02:24 PM
CRIVERHD12
Feb 23, 2005 01:24 AM
serpentsjv
May 20, 2004 09:36 PM
fishin fever
Feb 22, 2004 08:32 PM
sawboywv1
24
Jan 26, 2004 10:24 AM
