3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
09 USERS I Need help
Old Feb 19, 2011 | 02:25 PM
Navy7797's Avatar
I'm drilling my exhaust for the EGT probe and it seems that I maybe hitting a rib inside, I have drilled .348 and have not broken through. How thick is the wall on the manifold ? I took the inter fender well out and that give good access. I will post a picture very shortly of where I started the hole.
Any body that has drilled an 09 or one with the same manifold please chime in. Thanks
Old Feb 19, 2011 | 03:40 PM
madhat's Avatar
Administrator/Jarhead
There is a divider in the middle of the manifold there...
Old Feb 19, 2011 | 03:44 PM
AH64ID's Avatar
The 6.7 manifold I had on the shelf for a while didn't have a divider. The 6.7 manifolds are thicker thou.
Old Feb 19, 2011 | 04:03 PM
Navy7797's Avatar
thickness
I'm just short of 3/8" deep with the drill now. Maybe I should just drill the collector instead, really wanted it where it needs to be. Any other inputs ?
Old Feb 19, 2011 | 04:07 PM
AH64ID's Avatar
You should be good there.. IIRC that's right where the hole was in the manifold I bought.. It even looks the same as this pic.
http://www.dieselmanor.com/diy/CMS67.../D67image1.htm
I just did some searching and read that some folks claim their manifold is up to 1/2" thick in that area.
Old Feb 19, 2011 | 05:35 PM
Ahab's Avatar
There is no center rib in the 6.7 manifold. It is just very thick, keep drilling....
It may make some chattering as you start to break through.
Scott.
Old Feb 19, 2011 | 05:36 PM
Navy7797's Avatar
very deep
I'm now at .560" thats 9/16ths deep so something is very wrong. The pic that dieselmanor has is good but I'm not sure on the height in that picture of the hole location. it sure looks the same but I'm way to deep. Any thoughts
Old Feb 19, 2011 | 05:38 PM
Navy7797's Avatar
Scott.
Scott I just saw you post, wow that is thick, where did you get the picture ?
Old Feb 19, 2011 | 05:59 PM
madhat's Avatar
Good info, thanks for the pic.
Old Feb 19, 2011 | 07:22 PM
Ahab's Avatar
The picture came from another forum, I think the guy's screen name was MoparMuscle, or something like that.
Just keep drilling. Don't worry, when I did mine I thought the same thing. I have done two now - a 2008 and 2009 (mine), and they were both really thick. Probably 5/8" or so, I never did measure it.
Scott.
Old Feb 19, 2011 | 07:39 PM
Navy7797's Avatar
Thanks Scott
Scott: Thanks for your input and the picture. It gave me the confidence I needed to proceed drilling. Its done ! Used 60 different size drill bits to step up to the ltr "R" . Those pictures should be a sticky for the 6.7 side of the house. Thanks again for your time everybody!
Old Feb 19, 2011 | 07:43 PM
AH64ID's Avatar
Glad you got it done.
Old Feb 25, 2011 | 04:17 PM
Navy7797's Avatar
Temps
Just did a 900 mile run and the avg. temp seems to be 700-800 degrees except when getting on it then it will hit 1000. Is that about what everybody else is getting .
Also got 21 mpg hand calculated running 75-80 mph with Smarty jr set at stock with POD set down to 80%. Thats up from 16 mpg doing the same trip same speed. I'm so glad I did deletes !!!
Jim Lane
Apr 1, 2014 06:40 PM
RAM123
17
Mar 21, 2007 07:56 PM
RedRacer44
Jan 16, 2007 10:53 PM
4x4dually
Jun 20, 2005 05:43 AM
