06 2500 rear axle seal change
Old Jan 16, 2009 | 11:42 AM
workz's Avatar
anyone know where I can download a schematic for a rear axle seal change for my 06 2500 mega 4x4. Large pumpkin, cant remember the 2 different dimentions of the difs. Or does the axle have to be removed from the dif to replace the seal. Where is the seal located- in the housing, attached to the axle???
Old Jan 16, 2009 | 01:21 PM
CTD NUT's Avatar
The rear axle is a full floater - there are no axle shaft seals if that is what you are referring to. There are wheel bearing seals which are located in the back side of the bearing hubs. You will have to unbolt the axle shafts and remove the bearing hub assemblies to access them. The only other seal on the axle assembly is the pinion seal.
Old Jan 17, 2009 | 10:44 AM
workz's Avatar
workz
Thanks. After the hub is off is there any specialty tools required to get the seal out and reinstall.
Cheers
PW
Old Jan 17, 2009 | 10:56 AM
shortie's Avatar
On my 2003 aam 11.5 both rear hub seals started leaking in the first 50,000 miles replaced with dana 80 seals no leaks in the last 123,000 mi.
I realize this is not the correct seal but I had them on hand and the dimensions were very close so I gave it a try worked great.
Old Jan 18, 2009 | 03:59 AM
BigIron70's Avatar
Cummins Guru
REMOVAL
1. Remove axle shaft flange bolts and remove shaft.
2. Remove retainer ring (1) from the axle shaft tube.
3. Remove hub bearing nut (1) locking key (2) form axle tube (3).
4. Remove hub bearing nut with Socket 8954.
5. Remove hub and bearings from the axle.
INSTALLATION
NOTE: Axle flange bolts must be replaced or use Mopar™ Lock N' Seal or Loctite® 242 on cleaned existing bolts.
1. Clean axle flange and hub.
2. Install new axle shaft gasket.
3. Slide axle shaft into the axle tube.
4. Install axle shaft flange (1) bolts (2) and tighten to 129 N·m ( 95 ft. lbs.).
6. Pry out hub bearing seal from the back of the hub.
NOTE: The inner part of the seal (3) may stay on the axle tube (2). This part must also be removed with a pry bar (1).
7. Remove rear bearing.
8. Remove hub bearing cups with a hammer and drift.
INSTALLATION
1. Install outer hub bearing cup with Installer 8961 and Handle C-4171.
2. Install inner hub bearing cup with Installer 8153 and Handle C-4171.
3. Pack bearings with the appropriate wheel bearing grease.
4. Install rear bearing and install new grease seal with Installer 8963 and Handle C-4171.
5. Slide hub on the axle tube and install front bearing into the hub.
6. Install hub bearing nut with Socket 8954 (1) and tighten with torque wrench (2) to 30 N·m (22 ft. lbs.) while rotating the hub.
7. Back off nut about 30° and align next hub nut key slot with axle tube key slot and install locking key.
NOTE: End play should be 0.025-0.25 mm (0.01-0.001 in.)
8. Install retainer ring (1) with ring end in the key slot (2).
9. Install new axle shaft gasket and install the axle shaft.
RTillery
Feb 7, 2009 08:46 AM
pwrtripls1
Jan 7, 2008 08:55 PM
dieseljerk
Jul 8, 2004 07:23 AM
Paul Winey
Jun 22, 2004 08:09 AM
