5'th Annual Claremont Roundup
#62
You know I'll run as long as I don't lift the head in the mean time. I hit 42 pounds boost just playing around with a little water/meth. I don't know if the stock head bolts will take a much more of that.
#71
Sounds like I MIGHT actually might make it!!
Swap meet, nice idea, I have a whole bunch of first gen stuff that if someone doesn't want it, it will be going to the scrap yard, tired of tripping over it!!
#72
What are you bring? I could use a few things for my old Dodge like a fan upgrade, steering wheel that has cruise bottoms that ain't broken and some of the plastic interior pieces that trim around the doors and roof area. I've got the stock H1C compressor housing and compressor wheel and a box of stock disassembled worn out injectors. If I still have my boat I'll bring it. It's for sale too. Shucks I may even bring my better half. No reasonable offer refused. I sure hope she don't read this.
#73
Your attention PLEASE!!!!
We may have somewhat of an issue. The CVFD is adding a new bay to the back of the firehouse so half of the real estate that we normally use will not be available. As slow as it is going, I would not have a lot of faith in the addition being done in the next two months in time for our event. The area from where the dyno is usually set up back to the woods and a major portion of the back field will not be available. We will have some of the field where the 5'er people set up but space will be limited.
Dennis, Tim, and Sonny, maybe we better drive by there and see what we can come up with an see if we will have enough real estate and decide whether to continue, cancel, or look for other real estate in the area. I do not want to wait until the last minute to tell David we do not have the room to set up safely.
Are you guys up for a drive to the the fire house?
#74
That's a pretty big lot Joel. Most of the trucks park in the area to the left as you come in the driveway. I think that as long as Dave can get the dyno setup close to the building it should be OK. There's usually only a couple of fivers there anyways....
#75
