Xzt+ Surging
Xzt+ Surging
I've been having trouble with my xzt+ surging on the fuel and timing setting. The surging starts when slowly easing into the throttle up a slight incline. Everythings fine under heavy acceleration. The surging also stops when I switch to mileage max or off. The other day I pulled a loaded trailer and the surging was quite a bit worse under a load, a few times I had to shut the box off.
I've tried the 3K tune and 2K tune it still surges.
Is this just an issue with the box or do I have something going wrong with the trans or IP.
Any help would be great. Thanks.
Just tried the beta 1 tune seemed fairly smooth. I'll have to try it under a load yet.
For some reason or other the motor died under full acceleration just after the boost lit. Never had this happen before. Pulled over on the side of the road and it started right up again. Pavement was a little wet which cause a little more wheel spin, don't know if this had anything to do with it or not.
sCreamin400
11-02-2008 01:46 PM
buzzard1
02-29-2008 09:13 PM
bigwheels94
52
10-25-2006 07:26 AM
