exhaust upgrade and accessories.
Old 05-04-2016, 07:08 PM
Wyoboy's Avatar
I have a 24v with a exhaust brake and slightly larger than stock injectors. I also have a EGT gauge. I'm curious if I upgrade from the stock exhaust, to a 5" dual with maybe 8" tips. Will this affect my other upgrades? Any input is appreciated.
Old 05-06-2016, 12:11 PM
KATOOM's Avatar
Well hopefully you have more than just a pyrometer as you should also have boost and fuel pressure as well.....
As for exhaust, if your exhaust brake is turbo mounted and standard then your exhaust downpipe will be limited. You can find 4" exhaust systems that work just fine but I think 5" systems will require something larger.
That said, I wouldnt loose the exhaust brake for sake of a larger exhaust system as the exhaust brake is the far better trade off. And really you may want to read some other threads regarding 5" exhausts because generally they're too large to fit between the transmission and the frame and can cause contact issues. Plus running dual outlets will be really hard. If its looks you're after then thats one thing but 4" exhaust will not only be ample big for huge power but it will fit better.
Old 05-06-2016, 01:12 PM
Wyoboy's Avatar
That makes sense....thank you very much
sixb
09-19-2008 04:38 PM
89dieselkong
01-15-2008 08:49 AM
J_T
01-24-2007 06:53 AM
Murf
07-04-2006 05:26 PM
LanceK
04-26-2006 06:34 PM
Quick Reply: exhaust upgrade and accessories.
