Removing the factory toy hitch
When I installed my Reese class5 hitch I was asked to take some phots when I did my sons. He has been out of town and unable to do it until now. So here's some photos.
First one shows the hitch with the box already lifted and 3 inches of wood supporting it.
The second shows the hitch being rotated out, notice how little space there is.
Third hitch removed.
Fourth, using a small loader to lift the heavy Reese into position and hold it there.
Fifth the beefy hitch installed without the bumper which bolts to the hitch.
We also did a B&W goosneck hitch at the same time and because the bed was lifted we didn't have to cut the box to get the cross members in. Also having the bumper and factory hitch removed helped with access for the B&W.
Last edited by Blake Clark; 06-28-2011 at 08:53 PM. Reason: Cause I can! LOL! (really just to clean it up a bit)
The stock one is good for 500/5000lbs this one is good for 2000/18000lbs both "weight carrying". You can't pull hardly anything using the factory hitch unless you go up to a WD hitch and that gives 1000/10000lbs but no one uses a WD hitch with a work trailer so 500/5000lbs is it. The Reese is good for 2500/18000lbs WD.
Darn, I thought I could pull more than that on my stock hitch. Rephrase, I did pull more than that on my stock hitch. Guess I gotta stop.
How long was the process for your hitch installation? Direct bolt in, or was modification required?
How can they post this for the 2500 on their website? I purchased the heavy duty class IV towing package with my truck...and you are saying i can only tow 5000lb? I have towed over 10K many times?
Towing[1]:
15,450 lbs - max
Payload[1]:
2580 lbs - max
Quessing it says something like"when properly equipped"
WITH WHAT? If a hitch is going to fail, I rather it be factory installed then after market when it comes to any legal issues.
I also believe the DVD shows this payload capacity with the class IV hitch from the factory.
The hitch is a direct bolt in but one hole each side in the bottom of the frame rail has to be drilled. The 6 factory bolts are reused with new nuts and 4 new bolts are added at the front of the hitch.
My hitch doesn’t have a small little sticker saying 500/5000 anywhere. It’s bolted to the frame on both sides with 3 very long bolts and also to the bumper.
Is it remotely possible my 2011 2500 HEAVY DUTY 6.7 didn’t come with a 500/5000 receiver?
I still have the hitch I removed from my truck, there is no stamping on it.
