check eng lite
check eng lite
I just bought a 2010 dodge 3500 with a 6.7 Cummings it has a Performance Power Play mp-8 installed. It has been in the dealers shop for the last 60 days trying to clear some codes (p020) Injector timing #1 5 6 cylinders. Could the MP-8 be throwing the codes? if so how do i fix it we have replaced all the injectors fuel rail and injector pump and the wiring harness still same codes. I unhooked the MP-8 and got a throttle control light (ETC) I'm stuck ready to give it back to the dealer and find something else
ANY help out there
ANY help out there
Cummins Guru
Do you mean a P0202? The only part you haven't changed that would set that code is the ECM. If they replace ECM remember to pull the injector codes first.
