Tow mirrors Kool vue
Old 03-03-2012, 08:29 PM
rams2500's Avatar
I have searched a bit and found everyone seems happy with the kool vue mirrors. I'm looking to replace my little stock ones with something power and heated. Finding prices of $330 for what I'm looking for. Just wanting to hear a little additional feedback on my options. Ebay type or spend the $$ for the kool ones. Thanks in advance!
Old 03-03-2012, 11:03 PM
Otis's Avatar
I bought mine through discountautomirrors.com I think they were around $200 for the pair.
-Jon
Old 03-04-2012, 11:39 AM
SIXSLUG's Avatar
I'd suggest going with the Kool-vue's. They fit, the wiring harness is correct and they operate as the stockers do.
Make sure you get the backing plates that the heavier tow mirrors require, or they won't mount correctly.
Also, there are pathways for the wiring in the mirror arm. Be sure to route the wires and test fit so you don't pinch any wires when you mount them. Just a heads up.
You will probably need to shave a bit off the back of the control switch, also. No big deal.
Old 03-04-2012, 12:22 PM
Dane's Avatar
I'm in the process of installing these right now -
http://www.truckchamp.com/products/T...M-2500-PICKUP#
They come with the reinforcing plate rather than having to purchase them seperate. I've already plugged in the connector and tested the motors. I'll post again once they are on and I've driven a few miles.
Old 03-16-2012, 03:54 PM
Dane's Avatar
Mirrors are on and test drive complete with cab over camper on the truck.
Pro's
They work fine, I can see very well on both sides now.
They don't vibrate
Power and heat works with factory connector
Big mirror face with small spot mirror
They come with reinforcing plates in the box, don't have to buy seperately.
Less expensive than the other suppliers
Tech support answers the phone
Con's
Had to call tech support for replacement studs on the passenger side as they were too short. Tech support mailed 6 replacement studs the same day, no charge.
Also... I JB Welded the studs in the mirrors so they don't vibrate loose later. Recommend you do the same on any tow mirror.
Old 03-16-2012, 09:34 PM
Thundercraft's Avatar
You will not be disappointed with the kool-vue mirrors.
...and don't worry that you could maybe have saved $50 or something doing it another way.... after your first tow, you will not regret having those mirrors.
Old 03-17-2012, 11:19 AM
SIXSLUG's Avatar
You will be happy with them.
Old 03-19-2012, 11:05 PM
rams2500's Avatar
Ordered 2 sets and got a price break. Kool vues on there way!
Old 03-23-2012, 05:45 PM
cowboykilla235's Avatar
anyone have a problem with these vibrating? ive had my mirrors on for almost 2 years now and they wobble pretty bad. i dont remember where i bought them, is the mirrors vibrating or could it be the studs?
Old 03-23-2012, 11:02 PM
SIXSLUG's Avatar
Mine seem to dislike side winds around 70 mph and rough lanes on the highway.
You can shake the mirror and tell if the studs aren't tight.
Old 03-25-2012, 07:11 PM
hawaiianbro's Avatar
Mine vibrate a bit too much as well, especially when they are flipped out. Haven't had the time to tear em down and see what it is.
Old 03-26-2012, 09:39 AM
ya i heard you can take em apart, and i tired and chipped a piece of my mirror.... so i stopped! they dont seem to bad when there flipped out, i also dont like the passenger mirror. it needs to be a broader mirror.
SIXSLUG
11-18-2012 07:57 PM
mstep3
01-05-2011 06:48 PM
SUPRHLR
10-22-2009 05:19 PM
Canuckville
08-24-2009 06:29 AM
Bubspc
08-14-2008 11:22 PM
Quick Reply: Tow mirrors Kool vue
