Cab/frame differences
To use the solid front axle you would have to start with a 4x4 chassis. The 2wd 3500 pickup uses very different front end geometry. The solid front axle is used on the c&c truck lust like the 2500, 3500 4x4. But instead of being used as a drive axle, it is only a hollow tube.
So if you get a bare 4x4 frame then yes the front axle will swap over. For the rear the shocks and springs are the same. Just different amounts of leaves and blocks. The rear end is in fact narrower, But the frames are the same width for both. If I remember right its 38 inches outside to outside the rails. So you will need the rear axle from the pickup. Whether you go single wheel or dual wheel is up to you. But the rear axles are different for dually pickup, single wheel pickup, c&c. They all mount the same on all configurations, just different dimension on total width not spring perch width. I have done the rear swap myself on my 97 from single wheel to c&c rear so I know it all fits.
Drove it for a couple of years until he dropped a tree on the truck.
I had a buddy that stuck a regular 8 foot dually bed on his 1998 C&C, worked just fine except for the wider gap between the bed and cab. He made up some sheetmetal spacers and it didn't look bad at all.
Yes the springs will work, but remember ride height, you may have to put some blocks from a 4x4 or something to make up the difference. And with that comes longer u bolts to hold it all together. Whatever rear end you decide to use, just make sure you have the floating axles for it. They also vary in length according to application. The brake drums are the same for c&c dually and dually pickup. But with different width dimensions come different length axles.
One caution I have against the pickup frames is they have a factory rivetted splice in the middle that likes to breed rust and waste away. I've cut up and scrapped both frames of my 2ndgen donors because of this problem. The joint is right where the front leaf spring hanger lands.
The true C&C frames I've seen have a continuous frame rail through that section. Not sure if that hold true for all of them or not....
I also know that SRW to DRW pickup (and vice-versa) the frames are the same.
gts95
08-27-2007 10:13 AM
ptgarcia
09-12-2006 06:04 PM
