Alternator not charging tach is working
Old 01-10-2017, 07:07 AM
at7615's Avatar
Having trouble with a 1998.5 3500 24 valve, vin 3B6MF3666WM282782
Only gauge working is tach
Cluster will not self test (no gauge sweep )
Codes 920, 921, 999
ABS, wait to start, low fuel, brake, lights are working
Checked and cleaned all fuses, relays and connectors (PDC onleft fender and FP on left side of dash)
Pulled cluster all pins straight
Will double check fusible links and grounds this morning.
Old 01-10-2017, 08:21 AM
AlpineRAM's Avatar
920 The cluster is not receiving a vehicle speed message from the PCM.
1. Check the PCM software level and reflash if required.
2. Use a DRB scan tool to verify that the vehicle speed message is being sent by the PCM.
921 The cluster is not receiving a distance pulse message from the PCM.
2. Use a DRB scan tool to verify that the distance pulse message is being sent by the PCM.
999 An error has been discovered.
1. Record the failure message.
2. Depress the trip odometer reset button to continue the Self-Diagnostic Test.
Looks like you have a CAN-Bus Problem....
HTH
Old 01-10-2017, 08:36 AM
at7615's Avatar
more info
Howdy and thanks, I have a scanner, i'll hook it up,
how do check software level and flash the PCM?
I.ll do the reset after the message is done
What is the CAN-bus?
Old 01-10-2017, 12:29 PM
at7615's Avatar
Put scanner on (OBD II) scanner says can not connect?
Old 01-10-2017, 01:15 PM
AlpineRAM's Avatar
OK, now I have a little more time.
There is a digital data bus in the truck (CAN-Bus) that connects modules like the gauge cluster, the powertrain control module, the engine control module etc in a network.
The OBD scanner also uses this bus to talk to the PCM and gets the data from there.
At the moment it looks to me that the PCM can not talk to the gauge cluster and to the OBD plug correctly.
The DRB scantool is a Chrysler tool that can connect directly to the CAN bus and that can also be plugged into the modules alone with an adapter. This enables the technician to isolate faults rather quickly.
Since you won't have this tool and the software subscription, my suggestion is that you start looking at the PCM, it is located at the passenger side of the firewall under the hood. Take a cood look for any kind of damage to the wiring.
If you do not have it yet, treat yourself to a factory service manual.
Old 01-10-2017, 03:11 PM
at7615's Avatar
manuals
where's a good place to get digital manuals?
Old 01-11-2017, 02:07 AM
AlpineRAM's Avatar
Print
https://www.genosgarage.com/product/...ervice-manuals
Electronic
(I am not affiliated with Geno's, just a satisfied customer)
Diesel-Dan
20
09-22-2019 09:34 PM
Smokin96_12v
01-21-2010 01:06 PM
5.9Excursion
03-13-2008 07:08 AM
MSM
03-12-2006 12:46 PM
miningman
11-02-2005 07:34 PM
Quick Reply: Alternator not charging tach is working
