Weird Oil Plug - Needs A Torx Wrench???
Hope someone can help. I have a '96 1ton dually that I hardly ever drive. I have had the oil changed in the past at a shop. I decided to do an oil/filter change myself at home and was stopped in my tracks when I saw that the drain plug apparently needs a Torx wrench to take it out. I don't know what size wrench it needs and I don't want to have to buy an entire set of Torx Wrenches. Anyone know what size wrench I need.
Thanks in advance,
Doug
Thanks in advance,
Doug
If its a torx then its not original,, my both my trucks use the same plug and its just a 3/8 in square,, all i do is use my 3/8 ratchet on my plug. DO NOT over tighten them, as they will bend and crack the drain plug. I believe the right torq is 40 pounds.
I talked to a guy at Napa auto parts and he said a friend of his has talked about having to use a Torx wrench to take out drain plugs in Dodge Diesel trucks. He tried to call him to find out the size but couldn't get ahold of him. I also did a search on this forum and found only one other guy,(Jarhead), looking for the size of the Torx wrench needed for the Oil Pan Drain Plug. Nobody knew, because nobody else has one. I PM'd Jarhead to see if he could tell me the size.
Doug
Doug
Get under there and REALLY eyeball it, up close and personal...
Cummins puts a 3/8" square drive plug in all these engines from the factory.
I admit, it's not a very deep 3/8", but a 3/8" square drive nonetheless.
I use a 3/8" sq drive, right angle gear drive ratchet with a T-bar on the bottom of the handle. It is called a "Sidewinder" and I use it to remove and re-install the plug without getting any hot oil on me.
Picked it up from Harbor Freight. (darned thing is made in USA too!!!)
I'll get going on it this morning and let you know how it turns out. I have changed the oil in literally dozens of personal vehicles and never been stumped before. But, maybe I just give up easier now in my old age.
Thanks for the answers!
Doug
You don't have a buddy with an assortment of tools?
I am probably sounding harsh, but you own an expensive-to-maintain truck. A set of torx sockets aren't that much, and you will sooner or later need them for something else. Buy some and have what you need.
No, I don't have any friends because I'm a "cheap skate"!
no, he has an old 12v cummins; they are perfect for cheapskates like him and I...
I'm probably considered cheap because I use 70% recycled motor oil as fuel too, aren't I
trik396
05-31-2005 05:09 PM
