Garrett
Old 08-18-2009, 08:17 PM
Dr. Evil's Avatar
Garrett
Mike or Tater,
Can you guys ID this turbo?
Old 08-18-2009, 08:25 PM
Lil Dog's Avatar
Man.. That looks like something I would see on a Waukesha... But the MTU tag gives it up to a MTU diesel.. Luke might have some idea..
Old 08-18-2009, 08:49 PM
Dr. Evil's Avatar
My brother bought it - had no idea what he was buying...and I dont think he paid a lot for it.
He was putting it on his mustang
This is maybe the next step up for Kevin.
Old 08-18-2009, 08:58 PM
1-5-3-6-2-4's Avatar
looks like the turbo off a Detroit/MTU 2000 series. definately not off a 4000. those are way bigger.
I can run that part number tommorrow and probably tell you the original application.
Old 08-18-2009, 08:59 PM
Dr. Evil's Avatar
If you get a chance - thanks Bro
We tried running the p/n awhile back and didnt come up with anything.
Old 08-18-2009, 09:08 PM
you run the Pn through what system though?
lets get a shot of it from the side. like whole thing. the inducer isn't that big though. it didn't come off a big engine.
Old 08-18-2009, 09:12 PM
this is the inducer of a turbo on a big engine.
Old 08-18-2009, 10:06 PM
Dr. Evil's Avatar
Just tried running the p/n through google:
Old 08-18-2009, 10:19 PM
pind's Avatar
That is a Garrett (duh) BTV85.
The turbo OE number is 714322-0002.
The DD PN is the number on the tag in front of you.
the OE compressor wheel is a 448671-0019
the OE comp cover is a 706570-0002
The OE turbine wheel is a 448953-0003
The turbine housing is 441881-0037
Turbine wheel Inducer is 99.1, exducer 87.9 Comp wheel inducer is 74.7, comp wheel exducer is 102.3.
11 turbine wheel blades
hope that helps
Old 08-18-2009, 10:21 PM
Dr. Evil's Avatar
That helps immensely - thanks very much good sir !
Any idea what it was mounted on?
Old 08-18-2009, 10:26 PM
the HT4C I have in the garage has very similar wheel specs. that was off an older N14 I'm pretty sure. for sizing comparison.
Old 08-18-2009, 10:39 PM
I'm still betting it was on a Series 2000.
Old 08-18-2009, 10:47 PM
pind's Avatar
Look, I may be jammed full of totally useless information, but all I know, is judging by the product tag, it would have been mounted on something pale green, that leaks.
Other than that, I am of no use at all.
Old 08-18-2009, 10:53 PM
kennyblatz's Avatar
is that watercooled? ball bearing? can i try it haha
Old 08-18-2009, 10:54 PM
I'm not bad mouthing you if thats what you think.
these are Series 4000 MTU turbos. they look bigger I think. I'm going to do a couple 16v4000 startups tommorrow on frac units. I'll look closer.
Quick Reply: Garrett
