Front springs
Old Jun 22, 2005 | 08:41 AM
Paul S.'s Avatar
I put the skyjacker 2.5" springs on that I bought from summit racing and it did not quite level it out. I have heard of people using the 4" which more than levels it. Then they shim the rear, any of you out there? The ride is noticably better with the 2.5", good investment, but wish I had gone with the 4".
Old Jun 22, 2005 | 09:55 AM
apwatson50's Avatar
if you went with the 4" springs you would need to get a longer drive shaft and longer brake line, and possibly tie rod. When I got mine they accidently gave me the 4" instead of 2.5" and I didn't notice untill I went to put them on and I couldn't get the axle low enough, with the driveshaft still hooked up to get them into the spring mounts. So your looking at a lot more than just springs if you want 4" lift.
The ride is noticably better with these springs though. Mine rides a lot better than other trucks with stock springs.
Jordan5687
Jan 29, 2015 10:32 AM
53 willys
23
May 19, 2008 06:14 PM
95turbo4wd
Dec 12, 2007 05:59 PM
holeshot440
Apr 15, 2007 05:59 AM
bigred496
Oct 22, 2004 07:16 PM
