Exhaust pressure sensor?...help
Ok, so there's a stainless steel line going from the side of the exhaust manifold towards the thermostat, and into a sensor. I'm wondering what it is, what does it do, etc? I noticed yesterday the line was broken in half, before then I noticed everytime the exhaust brake would engage it makes a nasty squeeling sound. So I took the broken line off, and it worked totally normal no squeeling. Then I noticed it would pick and choose whe it would engage, and a cel came on for that sensor. Truck is deleted with h&s, I'm wondering how important it is, can I keep it plugged. Does that somehow relate to what the exhaust brake is doing or is that a seperate matter. Its at the dealer right now. Thanks!
Its basicly a back pressure sensor for the exhaust manifold the ecm uses it to help control the position of the fins inside the turbo ie your exhaust brake
If its is inop the ecm uses a default value for the eb.
Sent from my DROIDX using Tapatalk 2
Yes for the eb to work you need that line. It might not work at all or the eb will use a stored value in the ecm something programed in thats a "safe" number to run
Not covered. It was bolted to the bracket from the sinister delete kit that holds that coolant hose. So now I'm trying to figure out if there's something I can use with a flexible line.
Or, if you have a stainless welder handy you could daub it and sand it down.
Or just buy a new one.
dodgediesel
Nov 25, 2010 07:40 PM
Bobcat698
Mar 25, 2008 09:42 AM
Booost Almighty
Jan 1, 2006 01:41 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
