Best Brand of Diesel Fuel Conditioner
Old Oct 11, 2009 | 03:53 PM
DirtEater's Avatar
Where's everyone buying the Opti Lube products at?
Old Oct 11, 2009 | 03:59 PM
psd1's Avatar
Unless your looking for anti-Gel I think the "which is best" argument is the same whether its Coke/Pepsi, Kroger/Safeway, Shell/Texaco etc...alot is pure preference or what makes a guy feel better when they are filling their tank. I have tried the Power Service and now have a product from CRC that I will give a shot...I havent ever been able to notice a difference though...
Old Oct 11, 2009 | 07:56 PM
Nate-03 D's Avatar
http://www.opti-lube.com/
Old Oct 12, 2009 | 12:46 AM
LeonT's Avatar
I've probably used all of them at one point or another, and I've come to the conclusion that the more research you do and the more questions you ask on forums about this issue, the more confused you will become.
No more additives for me. I'm done.
Old Oct 12, 2009 | 01:47 AM
HMX-1's Avatar
FPPF to remove water in the fuel, and Power Service for the anti-gel/cetane boost/added lubricity for the fuel system.
Kris
Old Oct 12, 2009 | 09:53 AM
shonne's Avatar
Howes Diesel Conditioner Plus Anti-Gel has been good to my truck. It costs me about $10 for 1/2 gallon.
Old Oct 12, 2009 | 10:09 AM
Nate-03 D's Avatar
It's hard for someone to say that in cold states. I've seen to many gel-ups for me not to use a additive.
All you can do is keep a fuel filter on hand, your tank full and use some kind of a additive or make sure you can keep the fuel lines warm.
Old Oct 12, 2009 | 07:50 PM
billie's Avatar
^^No issues in Canada with our winter fuel. I've never heard of an issue up here with fuel from a reputable dealer. I saw -39*C last year on the top of the mountains.
Old Oct 13, 2009 | 12:02 AM
Bigiron's Avatar
The best scientific comparison of diesel fuel additives rated for lubricity is below. I use Opti-Lube Summer and every once in a while some Power Service Diesel Kleen.
http://www.dieselplace.com/forum/sho...d.php?t=177728
Old Nov 5, 2010 | 10:23 AM
Teich's Avatar
readthe test on all the additives some not so good stuff out there, what you thought was good isn't. Phones Pwoer Up as i us there 49D year round, was surprized fuel treated at there advertzed rate tested at .279mm which is 279 microns right at the top of the list now i know why the Dodge is so happy! should add traet rate is .08% or 1oz./us 10 gal. Laurie
Old Nov 6, 2010 | 02:45 PM
800rmk's Avatar
I usethe gen 49d also. Can get it readily from any UFA here in Alberta. The results of their lubricity tests are impressive. I have been using it for over a year and the truck runs better with it. Picked up probably 1.5 mpg too.
Old Nov 11, 2010 | 03:48 PM
DBLR's Avatar
For me Howe's is cheaper then PS so that is what I use unless I can't find it then I will use PS.
Old Nov 13, 2010 | 07:13 AM
Chip's Avatar
Stanadyne performance formula every fill up for the past 100k. No issues whatsoever!!!
Old Nov 13, 2010 | 07:17 PM
brassnadz's Avatar
Over the years I have tried alot of the additives, and used to use a botlle of Marvel Mystery oil with every other fill up. Nowdays with the reduced sulphur fuels, I am of the opinion that we do need to use additives to save the pumps and injectors. I dont live in an area where gelling is a serious concern, so for me I just want something to lube things up a bit. I use Stanadyne, and put the reccomended dose in every other fill up. If for nothing else, its peace of mind. If I never have any problems, I will say its because of the additives. if I do have problems, Ill probably be cussing myself for wasting the money!
Old Nov 13, 2010 | 07:33 PM
brassnadz's Avatar
Just to clear up my confusion, does this test mean that bio is the best? My current station sells fuel with a sign on it that says its a 15% bio diesel blend. Since the test results were best for what I take to be a 2% blend, then it would stand to reason (at least in my feeble mind) that 15% is pretty good, considering that they were using fuel that wasnt pre treated for the test. The bio blend, in addition to the additives the refinery puts in should be pretty slick, right?
