XZT+ 3000 TUNE help!
Old 08-12-2008, 06:55 AM
johnyb59's Avatar
I've been running this tune for about 3 weeks and i really like the throttle respose and the power it gives you. I have noticed that if I let the truck set and idle for a couple of minutes the idle will come up to about 1000 rpm. Is the high idle enabled in this tune or is it something to do with my vehicle. I am also running the 120 hp xillarader, 150 hp jammers. My truck is an 01 quad cab 4x4. Thanks for your time. Oh one more thing is there any tune that is better to run with these large of injectors. Thanks again, John
Old 08-12-2008, 07:07 AM
hamilton71801's Avatar
I'm running this tune and it does have the high idle and cold engine warm up. On mine the high idle is in the up position and the cold engine is always on until the motor temps hit 140*. As far as any other tune, I can't help you there.
Old 08-12-2008, 07:54 AM
high bid's Avatar
same here. I've noticed that when starting up high idle will engauge after 2min to 1k rpms for about 30sec and then all the way to 1200rpms. I think 1200 is the high idle rpm.
wyattearp29
16
11-19-2010 09:05 AM
highrpms
03-16-2008 08:35 PM
fishin fever
03-13-2006 06:46 PM
Quick Reply: XZT+ 3000 TUNE help!
