Wrenching Fun
Old 06-26-2007, 06:08 PM
tboling's Avatar
Talking Wrenching Fun
MY 1500 egt broke on me last sunday, I can't say to much the isspro was given to me by a friend 4 years ago. I ordered a new 1800 egt from isspro it's sweet should be at work at 12:00 tomorrow. I also got a valet switch for my afc housing it came off an old concrete truck thaf had air switch for the two speed. It was free, I bought a new fluid damper sfi. its all going to put on this week end Wrenching fun
Old 06-26-2007, 07:10 PM
TOMTOM's Avatar
Any chance of a TEST-DRIVE afterwards?
TOMMY
Old 07-03-2007, 07:55 PM
tboling's Avatar
yeup one problem the new egt works better than the old one the inter cooler is a must.
Old 07-03-2007, 08:07 PM
1st Generation Admin
BC847's Avatar
Yeah BoyHowdy!
Are you referring to a Fluidampr? Be aware, on my heap, the damper initially wanted to just >kiss< the backside of the fan blade. Had to move the fan forward to give about 1/4" space. If you're running a crankshaft position sensor, you'll need to get the sensor relocation kit cause the Fluidampr is larger in outside diameter compared to the OEM damper.
Are we having fun yet?
Old 07-03-2007, 10:01 PM
dpuckett's Avatar
QUESTION:
I have read about the Fluidampers, and know they are bigger than stock, but what is the advantage? Longer lasting? Better dampening?
Daniel
Old 07-03-2007, 11:47 PM
farmer0_1's Avatar
i have one on the bench for dad's dmax. after replacing the dual mass flywheel with a single mass flywheel i thought i should try and help the dampening effect lost by replacing the flywheel.
Old 07-04-2007, 10:36 AM
BC847's Avatar
Originally Posted by dpuckett
QUESTION:
Daniel
Better damping effect over a wider range of RPM torsional harmonic peaks as compared to the commonly seen resilient mounted ring. Cummins uses the fluid damper on some of their engines though I'm not sure which series. It's maintenance is covered in the operational and maintenance manual for industrial engines.
archer39
PADTR #15
07-29-2013 07:43 PM
Mike L
04-10-2011 05:16 PM
Black SunShine 04
05-10-2007 08:37 PM
Boatnik
01-18-2006 06:27 PM
Quick Reply: Wrenching Fun
