What in the world was that? (edited)
Old 02-14-2007, 04:52 PM
DTR question asker
dieselfuelonly's Avatar
I was getting on the highway today, and as most of you have probably read I think my tranny is starting to go.
I was doing about 65 on the on-ramp, and I put my foot on the floor. The truck did accelerate, but I also heard/felt this horrible vibration. Is it my TC going bad?
Last edited by dieselfuelonly; 02-14-2007 at 05:19 PM. Reason: TRYING TO FIX MY BOO BOO BY USING SYMBOLS TO REPRESENT CURSE WORDS BUT IT WON'T FIX THE SUBJECT SO DON'T KILL ME MODS :)
Old 02-14-2007, 04:56 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
could be alot...... could be a ujoint letting go..... could be you TC. could be your rear end. just start with the basics first and narrow down. good luck.
Old 02-14-2007, 05:13 PM
kd460's Avatar
Was it a TC shutter?
Old 02-14-2007, 05:20 PM
DTR question asker
Thats kinda what I'm asking... what does that feel like?
I was doing around 65, put my foot on the floor, and there was this heavy vibration, and a low sound. It was some kind of shudder, whether or not its TC shudder I don't know.
As soon as I let off the throttle it was fine. I floored it a few more times and it did the same thing.
Old 02-14-2007, 05:23 PM
JPR Ram's Avatar
i would think if it was a TC, the rpms would be going up and down all crazy like.
Old 02-14-2007, 05:32 PM
JPR Ram's Avatar
i'd check you tranny fluid. is it burned? or is it nice and red? block the tires, put the tranny in neutral, climb under and chech the drive shaft, ujoints, pinons yokes etc. also check all wheel bearing. i doubt those are your problem, but every one egnores 'em anyways, so i'd check. if not anything i've mentioned so far, drain the tranny. pull the pan and check for metal on the bottom.
i forgot to mention. check the fluid in the diffs or diff if you're a 2x.
Old 02-14-2007, 05:40 PM
Box5's Avatar
if it's the diff, you'd usually hear a whine, or metal on metal... i'd say u-joints, or TC are about ur best bet, most likely somthin in ur tranny since u said it was already acting up.
Old 02-14-2007, 05:48 PM
JPR Ram's Avatar
yeah i will agree with you Box5. i'm actually leaning more towards u-joints. I seriously doubt it's the diffs. but i actually just like to check the fluids while under my vehicle. just basic pm
DTR question asker
Yeah I'm guessing thats it.
So, its looking like I'm going to need a new tranny/get this one rebuilt.
Suggestions of sites that I can check out?
