Wood stove
Old Aug 26, 2006 | 10:56 AM
hamilton71801's Avatar
Wood stove
Anyone ever use one of these and are they worth the money? My stove has a blower but there is a huge amount of heat in the stove pipe.
heat exchanger
Old Aug 26, 2006 | 11:25 AM
ratat98's Avatar
I've seen one work in a store before and it sure put out a lot of heat....i cant see how it wouldnt be worth it!
Old Aug 26, 2006 | 12:19 PM
BearKiller's Avatar
They are good in theory; but, the dis-advantages out-weigh the extra heat gain.
We installed one, many years ago, identical to the one in the picture.
Tons of heat came out of it.
The problem is, this loss of flue heat causes draft problems, and premature flue blockage.
A hot flue will be a clean flue.
This is the same reason that so-called underwriters lab approved automatic stoves are notorious house-burners; they lose all the heat in the stove, so the chimney is cold, causing rapid blockage, then flue fire.
Also, the little tubes in the pipe mounted unit will soon deteriorate, especially from one season until the next.
Old Aug 26, 2006 | 12:37 PM
Mountaineer's Avatar
yea ive used both it and a homemade version my grandpa built for the garage.
They work great and are well worth it.
redneckonthenet
Jan 5, 2008 02:55 PM
CASMOKIN
Dec 11, 2006 06:57 PM
tboling
Oct 14, 2006 08:54 PM
4x4dually
Dec 14, 2005 06:29 PM
redneckonthenet
Oct 18, 2005 03:26 PM
