Wiring diagram for horn
Old Jul 4, 2004 | 11:03 PM
Sidewinder's Avatar
Question Wiring diagram for horn
Anyone got a wiring diagram and/or wire colors for the horn circuit for a '95? I have been trying to figure out why mine won't work but the Haynes manual doesn't show the horn wiring (I know I need the Dodge manual). The relay for the horn will not even "click" when the button is pressed and I an trying to trace the wires from the buttons on the wheel to the relay.
Thanks!!
Old Jul 9, 2004 | 11:08 PM
Scubasteve's Avatar
Just a thought but does the wheel have wires to the steering column or a disk with contacts running on it?
could very well be something like that.
Watch the air bag if you decide to get in there to have a look.
Jason
Old Jul 10, 2004 | 01:54 AM
infidel's Avatar
It has wires, also known as the clockspring. They do go bad, most times you will also lose cruise control and the air bag light may come on. They were under recall on some years.
Old Jul 11, 2004 | 10:17 PM
Sidewinder's Avatar
The clockspring was replaced already, and as for the airbag - that's why I was looking for a wiring diagram. The cruise works great so I want to be able to check the wires from the steering wheel/column to the rest of the horn stuff.
Thanks!
Old Jul 13, 2004 | 05:14 PM
Moose10's Avatar
Have you tried to make the horn work with just some jumper wires? Bad fuse possibly? Is the horn disconnected, or have corroded contacts? Broken wires?
Try chasing the wires from the horn itself first.
Better yet, put an airhorn on your rig
Old Jul 14, 2004 | 05:42 PM
Sidewinder's Avatar
I like the air horn idea!! but first I would like to check the wires coming from the steering column. The horn works (makes noise connected directly to the battery) but the relay does not click-fuse is OK. This is why I was looking for a wiring diagram or wire color codes.
Thanks!
ta3834bbl
Dec 30, 2004 05:29 PM
SEmerson
Aug 10, 2004 10:15 AM
Johnny
Jun 16, 2004 08:33 AM
HydraulicGuy
Feb 28, 2004 04:19 PM
Stevenc
Nov 21, 2003 09:05 AM
