Wire Tap On Edge Juice?
Old Apr 24, 2006 | 12:15 AM
efrantz's Avatar
I Just Installed The New Edge Juice With Attitude Today And So Far It Is Great. I did tap the pump wire but I am not sure if I tapped the right one. How Can You Tell? I tapped the upper most wire! Is This Correct? Thanks For The Help!
Old Apr 24, 2006 | 12:36 AM
MLR1's Avatar
The wire you need to be taped into, is the one closest to the block of the two wires. It is inside a protective cover (some kind of fabric material) that runs from the rear center of the pump (where the fuel lines exit to the injectors) up to the top of the pump.
HTH
Max
Old Apr 24, 2006 | 09:08 PM
whiteVLX's Avatar
Top wire is the one you want.
Old Apr 25, 2006 | 08:06 AM
BarryG's Avatar
One way to tell for sure is whether or not you notice a significant change in power from level 1 to level 5. There will be no mistaking the difference in the seat of the pants meter.
Old Apr 25, 2006 | 02:59 PM
tempoffroad's Avatar
I was thinking that i taped the one closest to the block but it was behind a rubber cover not the one with the cloth. Is this not right. If you stand over the pump it is the wires that were closest to the hood not the ground.
Old Apr 25, 2006 | 04:17 PM
sosborn's Avatar
Check out page three of this pdf file. It has a pick of the pump wire.
www.power2it.com/pdf/DodgeCompInstructions.pdf
Hope that helps.
Sam
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
mudwisr2
13
Nov 12, 2008 09:09 PM
notpowerSTROKIN
Oct 16, 2007 11:24 PM
Hoss
Apr 11, 2006 11:37 PM
