Which relay for trailer right stop/turn?
I'm not getting any juice to my trailer receptacle's right turn/stop pin. I'm getting continuity from the trailer receptacle forward to the C217 connector behind the left front fender, and the fuse is good (getting juice there too), but I can't figure out which relay in the IPM controls the trailer right turn/stop lights. It's not marked on the IPM cover nor is it in the service manual. What am I missing?
Hoping it's just that relay and not something else.
Are you ready for this? The relay is inside the front control module aka the fuse box. What a brillant move on Chrylsers part. My truck has the same problem and the module is bad. I would like to see if I can wire in an external relay because replacing the module would cost around 400. And I personally would not buy a used one seeing how many have failed. I would have to look at my wiring diagram tonight to be able to tell you what wires need to control the relay.
I still need to check continuity from C1 to C217 but I'm guessing it's the relay.
gcliburn
18
Apr 11, 2013 12:19 AM
gcliburn
Feb 2, 2013 11:42 AM
00Dog
Sep 19, 2006 05:21 AM
