Which is harder on the trans?
Old Sep 11, 2007 | 10:09 PM
2007 5.9's Avatar
I drive like a grandma most of the time. I drive with my SMARTY on SW#3 most of the time but once in a while I will roll out SW#5. As I said I drive like Ethel, but on occasion I do like to "Roll some coal". With SMARTY, which is harder on the trans, lugging it around 1600-1900rpm's and rolling the coal or slamming the pedal down and running through the gears? I only lug it when I want to roll some coal, other than that I drive normal, very light on the go pedal and no jack rabbit starts. Just trying to see what I can do with this SMARTY to not ruin my trans.....
Old Sep 11, 2007 | 10:43 PM
JCLeary's Avatar
Personally I think you'll do the least damage with the TC locked...
Old Sep 11, 2007 | 10:45 PM
2007 5.9's Avatar
Thats what I was hopeful for....
Old Sep 11, 2007 | 10:46 PM
soulezoo's Avatar
DTR 1st Sergeant
^^^ what he said x2. I ran higher levels in Smarty with no problems even though it is not, and I do not recommend it. The difference was I drove conservatively until the TC was locked.
Old Sep 11, 2007 | 10:47 PM
2007 5.9's Avatar
That is what I do....I always wait for TC lock up before I roll the coals...
rustyshakelford's Avatar
i used to think like that, until my TC got a bad shudder when it was locked and i got on it! now i just mash the motor when the rpms are higher and it seems to like it alot better!
brett
Old Sep 11, 2007 | 11:05 PM
Raspy's Avatar
From: Smith Valley, NV (sometimes Redwood City, CA)
With my Smarty on level 3 I was able to slip the TC in lockup. Be careful. Lugging means a high EGT and working it hard at 1600 RPM means a possible burned up TC clutch. Watch the tach for signs of slipping. Better to get the revs up.
John
Old Sep 11, 2007 | 11:12 PM
Raspy's Avatar
Hey John,
Looks like you got a new truck! Cool. I predict a new TC, VB and input shaft soon.
John
Old Sep 12, 2007 | 06:41 AM
SSminnow's Avatar
Heat is the #1 killer.
Old Sep 12, 2007 | 06:50 AM
omaharam's Avatar
I would have to disagree. The weekest part of the 48re is the TC. Before it's locked, it's suppose to slip. The problem comes in when it is suppose to be locked and the truck has enough power that it slips those locked clutches.
Old Sep 12, 2007 | 07:05 AM
tcr's Avatar
tcr
I have burned up forward clutches and bands in two 48REs, so I would say hard launches and WOT runs is the hardest on "stock" or "lightly modded"(TC/VB) trannies. My TCs have been fine, and I drive my truck like I stole it.
Old Sep 12, 2007 | 10:44 AM
JCLeary's Avatar
Sure, it's supposed to slip saving the rest of the trans.
This is fine, until the computer tells the TC to lock at WOT after a 1-2 shift.
When a TC is already locked, it can hold a lot more power than say, a TC that is unlocked and then told to lock. The slipping clutch then has to overcome the torque of the motor and stop the slip, as opposed to simply holding the the torque when already locked.
I learned this drag racing my '03 with a NV5600 and a stock clutch. If I hammered the throttle in gear with the clutch out, it would hold. If I hammered the trottle before the clutch grabbed after a shift, it would not grab until I lifted the throttle.
The same will apply to a TC. The only real difference is that the TC is a wet clutch.
Old Sep 12, 2007 | 10:53 AM
crownsey54's Avatar
when does the tc lock up. what speed.
Old Sep 12, 2007 | 11:39 AM
omaharam's Avatar
No. With an extra 100hp with the truck already locked in 4th gear, if you mash the pedal it will slip the TC. I know this for a fact as I have done it with two different trucks.
Old Sep 12, 2007 | 11:43 AM
SSminnow's Avatar
90% of the posts indicate slippage as the main problem. Slippage causes heat. Heat kills the trans. Am I being a bit to technical?
