water / alcohol
Old Jun 7, 2009 | 06:57 AM
doug60's Avatar
water / alcohol
I know most run water meth.
But for those who run water alone,
What effects will running 20 % denatured alcohol have on combustion?
I plan on running to 20 % alcohol for winter freeze protection.
Are there any benefits running it year round?
I read alcohol has a lower flash point than diesel. But I don't know how it will effect combustion / cylinder pressure / combustion temps.
Old Jun 7, 2009 | 09:41 AM
trik396's Avatar
I don't know about running denatured alcohol but if it's similar to methanol it will somewhat advance your timing which increases cylinder pressures. 20% should be safe. Read up some more because I am no expert. Many here would suggest water only. I picked up around 30hp with around 20%windshield washer fluid and 80% water filled in my tank. That probably equated to only 10% or so of alcohol. Hard to tell exactly what gain I had because I was running a slightly different tune from a previous dyno session. Water does keep temps down and that's what I needed it for primarily.
Dave H
Aug 19, 2005 08:30 PM
