Valve cover leak
Valve cover leak
Is the valve cover assembly in two pieces? I seem to have a leak at the bottom half at the cyl head. I can't see a gasket there like i can see at the cover itself. It almost looks like a spacer between the valve cover and the cylinder head. Any body else have a leak there?
Mine seems to only do it in the winter. It's coming from under the the rocker cover. I removed the valve cover and snugged all the rocker cover bolts and it's alittle better. To replace the
rocker cover gasket......I think I'll let it weep. The dealer could do more damage than good and I don't to do it either.
When I pulled the valve cover off I inspected the rocker asm. carefully... lots of wires 12 in all.
2 ea to 6 injectors and then where the wires exit the rocker cover as well. Not worth the hassle imho. After I torqed mine down alittle it has slowed way down. Not that is was ever really bad anyway.
Delectric
23
07-29-2007 11:58 AM
