valve body
Old Feb 2, 2011 | 02:44 PM
jughead's Avatar
valve body
looking for a reasonably priced reverse pattern 518 valve body. found 2 different ones but 900 bucks is just a little much.
Old Feb 2, 2011 | 06:06 PM
theidlemind's Avatar
I'd like to find one too. Supposedly Goerend makes them on request.
Old Feb 2, 2011 | 06:15 PM
BC847's Avatar
1st Generation Admin
You can save a LOT of money by rebuilding/reconfiguring what you have yourself.
I strongly recommend one call you favorite shift-kit maker and tell them exactly what you plan on doing with the truck, and let them steer you toward that which will serve you best.
Old Feb 2, 2011 | 11:45 PM
Dean Snow's Avatar
TransGo kits have always treated my transmissions well, not sure if they do reverse pattern
Old Feb 3, 2011 | 03:43 AM
jughead's Avatar
valvebody
i can do the 3 speeds have done them for years. i even found one company that wanted 900 bucks for the 3 speed valvebody which is totally uncalled for. when i could buy the seperater ? plate one could do it in a hour plus cleaning the valve body.
Old Feb 5, 2011 | 06:44 AM
jughead's Avatar
none of the above have a reverse valvebody or a kit to make one. will keep looking. guess the old man has just been out of the loop too long.
Old Feb 5, 2011 | 08:32 PM
tboling's Avatar
Try Suncoast! I'd say there pricey but you get what you pay for. That's what I have on my 95 it's a 47rh they should have something for the 518. BD Also has very reliable valvebody's
Old Feb 6, 2011 | 05:23 AM
jughead's Avatar
pricey is an understatement.
Old Feb 11, 2011 | 04:38 PM
jughead's Avatar
valvebody
kinda looks like old man will have to try it alone. since 4th is electric it shouldnt be too hard. just have to do more hit or miss than i wanted to.
Old Feb 11, 2011 | 07:31 PM
huntinguy's Avatar
What about a manual VB where do I get one without spending lots of $$$? Could I make the stock one manual? don't know much about autos.
Old Feb 11, 2011 | 09:46 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
Can somebody please explain what a reverse VB does differently?
Thanks in advance
Old Feb 12, 2011 | 05:47 AM
jughead's Avatar
valvebody
only ones i have found were almost 900 bucks. i used to do the 3 speeds regularly so i KNOW someone is making a pile of money off them. with the reverse pattern one doesnt have to worry about over shifting to neutral or reverse. D-2-1 and 1 is high gear. i think the 4 sp. would just be a switch.
Old Feb 13, 2011 | 06:21 PM
Field_boss_cb's Avatar
Jughead, I wondering if you could do a sticky on the reverseing the valvebody. I for one, find what you are saying very interesting.
Old Feb 13, 2011 | 06:38 PM
jughead's Avatar
i dont know how to do a sticky but i will dig up my info and post it in the next few days. it has been about 10 years since i have done a 3 speed but the info is at the shop.
Old Feb 13, 2011 | 06:46 PM
Sounds good and thank you!
