upgraded steering do you need the pitman arm?
Old 06-03-2009, 08:22 PM
1985cucv's Avatar
for the upgraded steering setup do you need the pitman arm or can you just reuse the old one on your truck mine is a 03 thanks
Old 06-04-2009, 08:31 AM
enafzige's Avatar
Yes, you really do need the updated pitman arm, especially if you use the truck at all. If the front suspension articulates much at all, the old style will cause clearance issues and make contact...
--Eric
Old 06-04-2009, 08:43 AM
rogers259's Avatar
Does it take anything to get that arm off and back on? Going to do my upgrade this weekend and hope its just a direct unbolt/bolt to get that pitman arm off/on.
Old 06-04-2009, 09:30 AM
Ace
Ace's Avatar
Nah, Just unscrew the sector nut and it'll fall right off.
Old 06-04-2009, 10:33 AM
enafzige's Avatar
Well, mine took a pretty heavy pitman arm puller and some good wacks from a little sledge hammer and some bolt blaster... your results may vary!
--Eric
Old 06-04-2009, 10:43 AM
Pull Ya's Avatar
Ace,
Man you gotta have the magic touch! When mine fell off it suprised me so much I raise up and hit my head of the frame. Piece of cake.
This is the only spanish I know----El Torro pu pu!!!
Jay
Old 06-04-2009, 11:13 AM
rogers259's Avatar
Ahhh...knowing my luck the pitman arm will be seized in place and require 4-6 hours of work to get off. Thats just been my luck here lately.
Old 06-04-2009, 03:54 PM
Pull Ya's Avatar
Have Ace help you
Jay
Old 06-04-2009, 09:11 PM
Mocho's Avatar
Just got to know were to hit it, a few love taps when a puller is on it and it will fall off. Granted I spent about 5 minutes wacking at it, on TWO trucks to have my old man hit it about 3 times and both times it comes off
They are on there pretty good, but a genaric puller and a hammer will take care of it....eventully.
Old 06-07-2009, 03:24 PM
BroncoHound's Avatar
--Eric
I've heard many people report this, but when my dealership updated the steering setup they did not replace the pitman arm. I got under there and looked at it and immediately went to talk with the service writer before leaving the lot. They got 6 techs to climb on the front of my truck and bounce it to get the suspension to compress while I was under the truck and the stud never came close to the tie rod. It sure looks like it is going to, but it doesn't. I told them I was still concerned and the service writer told me if it ever made contact they would swap the pitman arm with no charge. I don't do any pleasure offroading but take the truck down some REALLY nasty paths getting to some of the oil rigs out here and, in the 10K miles since I've replaced the front parts, the pitman arm stud hasn't yet made contact with the tie rod.
Old 06-07-2009, 05:02 PM
Danderson's Avatar
The Carli guys have found that under full compression the stock pitman arm does indeed hit.
Old 06-07-2009, 06:05 PM
Pull Ya's Avatar
For no more than the new style pitman arm costs and no longer than it takes to put it on I think you will be better off putting one on---IMO.
Jay
Old 06-08-2009, 08:27 AM
enafzige's Avatar
Hmmm, interesting. It may well not be a problem with the limited travel of the stock suspension; however, there has to be a reason that they designed a completely new arm to work in conjuction with the new steering upgrade.
With a suspension system that delivers increased travel, there will be contact made. The new pitman arm can be found for about $52, and takes less than an hour to put on. I'd keep an eye on it closely as you travel the rough roads for the first few times...
--Eric
Old 06-16-2009, 12:38 PM
paydirt's Avatar
Has anyone seen a part # for the new pitman arm?
Old 06-16-2009, 08:46 PM
kokalit's Avatar
I think this is it: 68039930AA
Available at these two places from about $53 to $55 not including shipping.
http://www.moparpartsamerica.com/par...layCatalogid=0
https://www.dodgeparts.com/oe_parts_...1b4a38108d5bd4
Quick Reply: upgraded steering do you need the pitman arm?
