U bolts
Old May 19, 2012 | 04:00 PM
bannerd's Avatar
U bolts
Anyone know the size of the Ubolt that goes on a 1991 W250? Also need to know the torque spec, I was in the middle of putting a ubolt on and it snapped in half.
Good news is I have new leaf springs!! Just my luck!
Old May 19, 2012 | 05:04 PM
simplysmn's Avatar
5/8 I believe
Old May 19, 2012 | 05:06 PM
Front U-Bolt ?
There are two different sizes. Passenger side has a larger U-bolt than the drivers twin set. The torque spec is 95 Ft lbs. wait a week or so of driving, and re-torque.
Old May 19, 2012 | 05:08 PM
PapeCAT's Avatar
The stock ubolts are 9/16" but you can step them up to 5/8" for extra beef, but you should torque them accordingly. 5/8" ubolts require higher torque spec than stock 9/16".
You will also need to hog out the spring plates to fit the larger diameter.
I had a set of 5/8" made up at the local spring shop for cheap.
Old May 19, 2012 | 05:11 PM
Oh,
I thought he wanted the spread of the u-bolt, and not the thickness of the bolt itself.
9/16" X 3 1/4" x 8 3/4" Round Bend; w/ Deep Nuts & Thick Hardened Washers; For Front Spring; Drivers Side
and
9/16" X 4 1/16" x 8 1/2" Round Bend; w/ Deep Nuts & Thick Hardened Washers; Front Spring; Passenger Side Outboard
I second the notion of having the local spring shop make them up. Cost me about $9 to have them make me a new u-bolt and it fit perfect.
Rock auto has them in stock from $6 to $9 something a piece
Old May 19, 2012 | 05:14 PM
bannerd's Avatar
Yep U bolt thickness!, So 9/16?
Old May 19, 2012 | 05:17 PM
Confirmed Smedly. You got it !
Old May 19, 2012 | 05:59 PM
longshotranch's Avatar
If you're putting new springs in you should always replace the u-bolts
Old May 19, 2012 | 09:42 PM
True.... AFAIK
according to the spring shop that did my springs, the u-bolts are a one time use product, as they're designed to stretch upon torquing. After unbolting them, they don't have the ability to re-stretch without possible failure, such as what was described in the OP, where they snap.
Old May 19, 2012 | 10:02 PM
I ordered the "9/16" X 4 1/16" x 8 1/2" Round Bend; w/ Deep Nuts & Thick Hardened Washers; Front Spring; Passenger Side Outboard" U-bot for the passenger side from rockauto and they sent me the complete wrong one, i was in a jam and googled spring shop in NJ real quick and found a spring shop 30 minutes away. He made me a U-bolt and gave me a cup of coffee for $10, Nice guy
95 ft lbs. is what he told me to torque a 9/16 u bolt too
Old May 19, 2012 | 11:09 PM
BILTIT's Avatar
http://www.lhrods.com/ubolttorque.htm
Old May 20, 2012 | 06:54 AM
I ordered t.... from rockauto and they sent me the complete wrong one, .......
happens a lot with these aftermarket companies (at least to me, anyway)
Went to a spring shop in NJ real quick and found a spring shop 30 minutes away. He made me a U-bolt and gave me a cup of coffee for $10, Nice guy
Spring shops the way to go. Experience and free coffee....
Old May 20, 2012 | 09:35 AM
bannerd's Avatar
So I've been all over and no one has these U-bolts. Napa had one close but it wasn't long enough. Is there a place online that anyone knows I can buy these?
Willing to spend the extra money for case harden ones.
Old May 20, 2012 | 09:54 AM
bannerd's Avatar
Do you have his website? Or phone number? hehe
Old May 20, 2012 | 11:53 AM
Hahah I don't think the guy knows how to use the computer. No website.
I wish i had more than one made for this reason.
Remember the driver side u-bolts are fairly common, the passenger side one is a rare beast because its 4-1/16" wide to go around the axle housing, the driver side ones just go around the axle tube.
Rockauto HAS the special passenger side U-bolt, It's Part Number- USB042R
Hopefully they send you the correct one,
